Question about DeLonghi D612 Cool Touch Deep Fryer
I have no manual for this deepfryer, and there is no handle for basket, can you help me figure this out please?
    Genius:
  • 1,739 Answers
Checked several of the global DeLonghi sites; the UH sites advises that manual for this product does not exist.
A handle for your basket can be purchased here:
http://www.abtecparts.com/delonghi_deep_fryer_handles.htm
Posted on Mar 15, 2011
Bravetti deepfryer manual
I wont try it, the beast way to clean glass is to use a oven cleaner than wash it real good with dish soap!
Dec 14, 2011 | Bravetti EP4305FS Deep Fryer
We want to take the Stroller Push Bar off and can't figure it out! Please help!
There is a push button at the bottom of the handle bar (by the basket). It's usually silver. I usually have to push with a screw driver or something on the button instead of just my thumb because it's a really hard to push(just be careful not to push too hard if you do then you have to fiddle with button up the tube to put it back in place). Once that is pushed in you have to pull the handle bar up. This is the instruction manual for the happy navigator but it should still be the same: http://www.kettlerusa.com/airnavigator.pdf (its on page 11) I provided a picture of where the button is.
Nov 08, 2010 | Kettler Kiddi-o Supreme Stroller Trike
Guy's We have a Vulcan electric deep fryer in our galley , I do not have the model number at present but what we are inquiring about is to see if there is available a metal cover to place over the Top...
look for a hardware store dealing with this problem they will give u the exact metal sheet of steel to make a cover so that u will be able to void fire and other things falling in the frywer
Sep 07, 2010 | Vulcan Kitchen Appliances - Others
Need deepfryer power cord
couldnt get the power button to come on
Jan 04, 2010 | Rival CZF625 Deep Fryer
How to fold peg perego 2008 Pliko P3
You also have to pull on the middle part by the basket it has like a handle.
Oct 02, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Apr 08, 2009 | Kenmore Refrigerators
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
Can't get tight fit between basket & steam ring
the proper replacement steam ring has an up-side & down side. the brew-head plate must be installed with the grooved side facing up; the steam ring has a groove in one side that fits over the top up the brew-head plate...does this solve the problem? if not, you may have the wrong steam ring/the brewhead plate may be installed incorrectly...oh, nov of 08...i seriously hope you've figured this out already. if not, you don't happen to still have machine in your possession, do you? if so, i'll buy it for $5.
Nov 26, 2008 | Breville ESP8XL Espresso Machine
Basket sticks - FrancisFrancis X1
I have the X1 and have this problem. I do two things - the first being (paradoxically) to tighten the handle a bit - that often frees the basket. If that doesn't work, I loosen the handle (to the point where it's quite loose) and then turn the pump on - that gives enough pressure to the basket to free it. So far, that's worked for me 100% of the time.
Good luck! -Greg
Nov 16, 2007 | FrancisFrancis! X1 - Stainless Steel...
Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Oct 23, 2006 | Whirlpool Ultimate Care II LSQ9564J Top...
DeLonghi D612 Cool Touch Deep Fryer Logo
117 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
