Question about Autodesk AutoCAD 2011 - 1 User - PC
When i tried to activate my autocad 2011, a blank screen was shown and all the icons cannot be seen. can you give me some help.
  • 117 Answers
DAER user,
may the vwersion u r using its not compatible for your pc.kindly use other version like 2009 or 2010
Posted on Mar 15, 2011
Activation code for autocad lt 2011
Nobody in their right mind is going to give away an activation code for an expensive program like Auto Cad.
Sep 24, 2014 | Autodesk AutoCAD 2011 - 1 User - PC
ACTIVATION KEY FOR AUTOCAD 2011 (pdf)
Hi Rodstan
Your activation key should have been sent to you by Autodesk either by email or with the product.
You can contact autodesk with the email you purchased the program with and have them check their records and retrieve the key for you.
I hope this helped.
Philipp
Apr 16, 2014 | Autodesk AutoCAD 2006
Code activation
Before you can use the AutoCAD 2007 software on your computer, you must import your license key into the program.
You received this license key after purchasing your copy of the software.
This key confirms to the software that it wasn't pirated, and allows you to use all the features available to you in the AutoCAD 2007 software for whatever length of time you choose
Open AutoCAD 2007 (if you haven't already) using the icon in your "Start" menu.
Click "Edit" at the top of the "AutoCAD 2007" program window.
Click "Options."
Click "Registration."
From this window, click "Activate Now."
Type your license key into the window on the screen and click "Activate."
This will import your license into the AutoCAD 2007 software.
utoCAD 2007 Tutorial - User's Guide
http://www.tutorialspdf.com/autocad-2007-tutorial/
Jun 03, 2013 | Autodesk AutoCAD 2007
Activation code for autocad 2012
As you approach to the point when the trial (unactivated) AutoCAD license expires (30 days between the installation and activation of your license), it may be neccessary to activate your license "on the fly", inside a running AutoCAD session (not on the AutoCAD launch). You can perform the activation with the ABOUT command. Click the buttons About the product > Activate and you'll get to the dialog "Autodesk Licensing", which is usually displayed on AutoCAD startup:
a2011activ1.gif Click the Activate button in this dialog. If you have received your activation code over e-mail, pick the option I have the activation code from Autodesk and in the numbered fields 1-16 enter the hexadecimal activation code from the e-mail. It is not neccessary to manually type-in the individual fields - just copy/paste the code as a single string (some fields may remain blank). By finishing the activation you will get back to your running AutoCAD session. a2011activ2.gif
Jul 14, 2011 | Computers & Internet
PLEASE GIVE ME THE ACTIVATION CODE FOR THE AutoCAD 2006 Serial number/Groud ID: 191-75444444 Request code: T4Y1 10D0 NCTC P27T NDNK
I Dont Have the activation code but you can try this one.. First Download this file
http://www.mediafire.com/?f57ttbww7np51zb
Then Extract the file.
Then Copy " _patch_.exe , AHTEAM and file_id " on your AUTOCAD installation folder.
(If you have an Shortcut of AUTOCAD on Desktop,Right Click then Properties then Click Find Target)
Paste the 3 files then Run " _patch_.exe " then click Patch.
Then your done.
Hope it helps..Have a Nice Day.
Jun 27, 2011 | Autodesk AutoCAD 2006
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Activating 2010 student version
try to find the registration code from the source where u download it. or if u had purchased it then ask for code again.
Jun 18, 2009 | Autodesk AutoCAD 2010
Autodesk AutoCAD 2011 - 1 User - PC Logo
364 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
