Question about Refrigerators
My LG Bio Fresh with freezer at the top was purchased nearly 7yrs back. Till date the appliance was working fine. All of a sudden I am observing that the FRIDGE IS FREEZING THINGS from 2-3 weeks. Please help me out to troubleshoot this problem. Regards Arp
  • Refrigerators Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Mar 19, 2011
HOW DO I ADJUST REFRIGERATOR TEMPERATURE
    1. Refrigerator Adjusting Temperature Controls. At initial startup both fresh food and freezer controls should be set at the normal setting or mid point settings. Temperature controls can be found in the back of the fresh food compartment, near the top of the fresh food compartment, or on the dispenser panel.
      Refrigerator Adjusting Temperature Controls - GE Appliances
      products.geappliances.com/appliance/gea-support-search-content?contentId...
    Feedback
  1. Refrigerator Temperature Control Dial - What Do The ...
    removeandreplace.com/.../refrigerator-temperature-control-dial-what-do-...
    Mar 4, 2015 - The more food you have in your refrigerator, the more stable thetemperature will be. Set the thermostat to the middle of its range and leave it for ...
Nov 28, 2015 | Refrigerators
The freezer side is freezing. The fresh food side is extremely warm. How do I fix it? The compressor is working. No ice build up on the condensor coils. Fan is blowing on the coils.
There is an opening on the lower portion of the wall that separates the two sides. check to see if this is closed. Sometimes, this happens in cleaning, etc. If it is open, reset the refrigerator setting at the top of the unit and see if the opening opens.
If that is not the problem, look inside the freezer down near the bottom at the back wall. There is a breather vent, I will call it, there. Check to see if it is frozen over or has excessive ice.
If it does, it probably is the Thermostat. There are two names used for the Thermostat in the parts/repair business. Some refer to it as Thermostat and some use the term "Metal Clip". One in the same. You can purchase this item from Appliance Parts or any appliance parts provider and put it on yourself as I did or you can call a repair person which will cost considerable more.
BEFORE COMMENCING ANY REPAIR, BE SURE YOU UNPLUG THE UNIT FROM THE ELCTRICAL SOURCE.
Now to get the bugger in. Take all food out, take shelves out, get approppriate screwdriver and remove screws from back panel and remove panel. You will see the Metal Clip/Thermostat clipped onto a brass tube that has some lead wires connected. Observe their allignment, unplug gently, remove old Metal Clip, Insert new Metal clip being sure to connect the wires. Put everything back together. Leave shelves and food out, until you see the ice melts to be sure everything is okay. I did this to mine when this happened to me. Ice won't melt instantly, but in a bit of time will. Good Luck. Let me know if it works for you.
Jul 17, 2011 | Frigidaire Refrigerators
Freezer is not working. was purchased less than a year ago
The entire refrigerator is still under warranty. I would call an authorized repairman.
If you still want to do some troubleshooting: Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 08, 2010 | GE Refrigerators
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer compressor running constantly
Below the evaporator fan behind the back cover inside the freezer is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
If it's heavy buildup-
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 18, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
How to check stuff>
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana Bottom Freezer 7 years old running but not cold.
How to check stuff>
Below the evaporator fan is the evaporator coils. Remove the back cover inside the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
heavy frost-
Aug 25, 2009 | Refrigerators
Motor is running but both refrigerator and freezer are not cooling
How to check stuff>
If the evaporator coils behind the back panel of the freezer are icing up(totally blocked) because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 22, 2009 | Jenn-Air Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
