Question about Panasonic SC-HT700 System
My panasonic stereo system SC-VK550. my cd is no open show in F61 Other not open my plyar what is this F61 How to my problem sholf how.
  • pbbddtk_25 Mar 15, 2011
    my panasonic stereo system SC-VK550. my cd is no open show in F61 Other not open my plyar what is this F61 How to my problem sholf how.
    Brigadier General:
  • 8,546 Answers
F61 usually means the amp has detected a short or has a microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 15, 2011
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
When i turn my cd stereo system, it doesn't work,only shows f61 and inmeditly powers it off
I suggest you Google Panasonic on your computer and pose your problem to them. They will tell you what the code means and what needs to be done about it to make the stereo work properly.
Jim Hart
Jun 20, 2010 | Panasonic SC-AK640 Shelf System
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
Press power it shows f61 instead of what it should show
You need to open the back of the system and change the fuse located on the right side of he panel. you can go to Radio Shack and get the fuse for $1.99.
Apr 06, 2009 | Panasonic SC-AK78 CD Shelf System
Problems with the panasonic cd stereo system
problems with the panasonic cd stereo system for some days.
The model no is SC- AK640 and i have been experiencing such problems such as "F61" and in the operating guide it says to check and correct the speakers cords i have done that but the problem can not be fix so please if you can assist me that willl be great thank you
Aug 31, 2008 | Panasonic 5 DVD/CD Micro System with MP3,...
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic SC-HT700 System Logo
188 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
