SETTING DETAIL OF THE WF-101AF TEMP. CONTROLLER NEEDED
Location of temperature controller
it is called a thermostat and is located where the temp setting control is
from there it has a small tube running back to behind the evaporator plate
get a technician if you are having problems
Jul 10, 2016 | Refrigerators
Dear expert of LG WF-F783PC (washing machine). i am using an LG washing machine model LG WF-F783PC.its giving a warning alarm after 3-5 seconds of operation (wash & spin mode)
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve.
It is best to remove them , check reset after cleaning.
Nov 02, 2011 | LG WFT1071TP Top Load Washer
Max therm 33300 btu temp is set at 98 but turns off at 94
What do you use to control it? If it's a separate controller (not the one on the heater) than these are adjustable temp. wise. You have to claibrate it. If you are using the controller on the heater than your thermostat is the most likely culprit, but that is a problem you could probably live with. Just adjust your temp setting higher.
Mar 30, 2011 | Sta Rite Pool & Spa
What is cooling and dehumidification mode
When dehumidification operation is set by remote controller,the intake air temp.is detected and the setting temp.is automatically set according to intake air temp. expl. Intake temp.78.8 set point will be 77. When intake air temp.is 2deg.below the setting temp.the indoor fan operates at iow speed or stops.It is just a way to controlle humitity rater than just temp.Some systems reach setpoint before enough humitity is removed,making house feel stuffy,or damp.
Mar 07, 2010 | LG LSC183VMA Split System Air Conditioner
I got your return answer on my hobart 175 turned the current on the highest setting. and still no penetration of the wire into the metal.
Try this, put WF on No 5-6, voltage on No3-4, check the weld appearance, if unsatisfactory reset the voltage to No 5, dont move the WF speed.
kenlets know your results.
Jan 26, 2010 | Welding Tools
I get a P1 error code on my Paloma tankless water heater. It blinks between the P1 and the tempature setting
Water inlet temperature to the heater is the same as preset on the controller.
I had this happen to me becouse I have a solar tank with temp of
135 farenheit.
Once I bypassed the sollar tank..no problem
Sep 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Wf 865 water does not seem to be heating up
The cycle does not advance because the temp sensor does not detect enough temperature.
The heating element must be tested using a multimeter , and eventually replaced.
Usually the element is the problem, if element is fine, the temp sensor and the timer control must be checked.
Apr 16, 2009 | Hotpoint Ultima WF865 Front Load Washer
What is the correct procedure for setting temp
You should still have a lower element. If the lower element doesn't get hot when the controller is set for 350 degrees, that's the problem.
Let me know
Feb 01, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
My marvel kegerator model 61hk keeps freezing the beer at every temp setting
replace the cold control (Temp Controller) it is not turning off the compressor
Aug 01, 2008 | Marvel Refrigerators
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
