Question about Samsung HTC550 Theater System
When i turn the stereo on it only goes on about 2 seconds n then it says PROT on the panel and turns off
  • 902 Answers
The PROT error can result in one of two things if you have a divx disk the system that could do it otherwise it results in a fault on an onboard fan to cool off the receiver. usually meaing a faulty fan. you can replace the fan easily. worst case is the board went bad and you may be able to find one on ebay for cheap. sorry for the bad news. but thats the reasoning behind it. i hope the bad news doesnt stop you from giving me a good rating lol! but really i am sorry about your problem.
Posted on Mar 15, 2011
Yamaha RX-V463 turns on and off after 3 sec
try the reset again and watch the display. is should say something along the lines of: PS PROT, DC PROT, or I PROT.
Mar 06, 2016 | Yamaha Audio Players & Recorders
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Feb 20, 2011 | Samsung HTC550 Theater System
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Oct 11, 2010 | Samsung HTC550 Theater System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
No picture, audio flickers on and off
THIS IS USUALLY THE MAIN TOTAL ASSY OR THE PANEL IS BAD.
Jan 30, 2009 | Televison & Video
Power issues
It sounds like you are drawing to many amps and you need to go to a higher capacity altinator and a second battery would be a good idea as well. Start your car (do it at night makes it easier to tell) turn on your headlights without your stereo on look at head lights and see how bright they are then slowly turn stereo on and up if headlights dim you are drawing to many amps and need a higher capacity alt to charge and stop you from blowing them, and second battery with and isolator so you don't draw amps from the battery that starts your car.
Jul 23, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung HTC550 Theater System Logo
975 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
