Question about Nikon Sb600 Sb-600
My NIkon SB600 is stuck on my hotshoe-I can not remove it fromt the camera (d80) help
    Guru:
  • Nikon Expert
  • 362 Answers
I had a similar problem with my SB25 when I tried to use it on a D90. I took the camera into the Nikon USA Repair Depot in Los Angeles where they took it into the back shop and removed it while I waited without charge. If the SB600 is like my SB700 and SB900's, there is a spring loaded dimple in the camera's hot shoe that clicks into a hole in the SB flash hot shoe. I think if you can slide a thin piece of metal such as a machinists shim, you may be able to depress the dimple and release the SB600. Let me know if it works.
Posted on Jun 18, 2014
Nikon d700 hotshoe missfire with flash nikon sb900
Probably a loose hotshoe. This is a common problem with the D700 hotshoe and SB900 combo. The weight of the SB900 eventually loosens the hotshoe, meaning the internal screws holding the hotshoe in place loosens.
Nov 13, 2012 | Nikon D700 Digital Camera
I want to use my nikon d80 with my sb600 and as a infrared remote
The Nikon D80's shutter can be released via handheld "IR" or infrared remote. You can buy them online or in most camera shops. The Nikon branded one will cost the most, but really doesn't perform a whole lot better than the $5 third party versions. The nice thing about IR remotes is that only a transmitter is needed. There's a built in IR receiver on the front of the camera body, and as long as it is not obstructed - or too far from the transmitter, it will work fine.
The SB600 will fire if setup to work correctly when the shutter is released "normally" - triggering with a IR remote will not affect the SB600 flash whether mounted on the camera or if in "commander mode". The D80 manual has details on pg 38 to operate in both the instant and time delayed IR operation modes and should be consulted as Nikon does not allow copy and paste from the manual - and they make use of graphics for button functions.
When distances are too great for the IR remote, you'll need to go the route of an RF or radio frequency remote instead. Many of these will work at distance up to and even beyond 100 yards. They consist of a transmitter and receiver. The receiver can be mounted on the hot shoe of the camera or tethered via cable to the camera body. This is not the question you asked about, so I won't go into further detail - but only mention it as another way of doing the same thing from greater distances or when you can not be in front of the camera to access the IR receiver on the D80 body.
If this was helpful, please rate it as such. Thanks and good luck!
Sep 29, 2011 | Nikon D80 and 18-55mm Lens Kit Digital...
My Nikon SB600 flash will only flash once nomatter the kind of battery.
Hello!
Please clean the contacts on the hot shoe and shoe foot, and confirm that there is communication between the camera and flash.
We are talking about a SB that works well until you put on the shoe.
Did not understand your explanation.
The flash will not turn on the display, and the ready light not lit.
Send to Nikon service.
Feb 21, 2011 | Nikon D80 Digital Camera with 18-135mm...
I have 2 Nikon D80's and a Bower 724AF speedflash
Set the flash unit to full manual.
Aug 12, 2009 | Nikon Cameras
Metz 45 CL Flash to use with Nikon D90
Metz in Germany advises Models CT45-1 with Serial No's 53400 or less have High Voltage triggers and must not be used on NIKON Digital Cameras Models D70 ,D80, D90 etc.and will damage Flash and even Cameras. according to a email received today. 21/09/2009 Models CT45-4 and 45CL -4 ore ok.
Michael T
Mar 20, 2009 | Metz 45 CL-1 Flash
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
Nikon d80, setting not remembered
I'm thinking it's an internal problem - probably needs fixing at Nikon. I can't think what else you can do.
Sep 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
Water got into my sb600
I doubt it. Water damage usually is fatal, or very expensive.
Aug 07, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 flash menu locked.
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes.
Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
Apr 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Sb600 Sb-600 Logo
181 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
