Question about Dyson DC28 Animal Bagless Upright Vacuum
I have a dyson DC28 vacuum and the power button flashes on and off and the beater bar quit turning. I turned it over and found some string caught on the beater bar which I removed, but the beater bar still does'nt turn and the power button still flashes on and off. I hope you can give me a solution to this problem.
I had the same symptom with my wife's DC28. The problem was associated with the cam driven height adjustment mechanism. The beater bar must rock freely up and down when pressing on the tabs that the end cam lobes actuate. On ours I found hair and crud jammed in between the end of the beater bar and the side of the vacuum head preventing it from moving freely. To clean it out I fashioned a hook tool by straightening a paper clip and bending the tip at 90*, then took a flat screwdriver to pry the gap open a bit so I could use my tool to clean out the buildup.
I removed the plate that holds the cam in place (6 torx screws) to gain access to the rocker tabs, although in hind sight I could have probably just left it in place. It doesn't matter how you set the cam back into place. It's self aligning with the aid of the micro-switches inside.
Hope this helps
Posted on Nov 27, 2011
What does a flashing light on the dc28 vaccuum mean
There are a few things a flashing light could mean. One is that the beater bar has something stuck on it. Or, it could be that the bag or canister is full. Then again, maybe something is stuck in one of the intakes. Be careful when checking the beater bars. Unplug the vacuum before touching them, you wouldn't want your hands getting injured or fingers broken:( Clear anything that is wrapped around the beater bars, hair, string, etc., and then check the hoses to make sure nothing is stuck in them. If you have suction, the interior is clear. If not, then check in there to make sure nothing is clogging it. Good luck and be careful:)
Jul 23, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
My Dyson DC28 Beater Bar will stop turning then start again. Then it quits all together and after awhile it will start again.
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC28's brush bar seems to be working intermittently. It may be worth taking a look at the video I've attached below, as this shows the correct way to check the cleaner head for obstructions and reset your machine.
If you would like some further advice from one of our experts, please give us a call on 1-866-693-9766 (US), or 1-877-397-6622 (US). We'll be happy to run you through some further diagnostic checks. We can also confirm if your machine needs a repair, and if this is covered under the terms of our 5-year warranty.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 05, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
I was vacuuming with my DC28 Animal and all fo a sudden the beater bar stopped working and NONE of the floor mode buttons work.. no lights or anyhting. I checked for obstructions per the Dyson manua
Check the wire connection that feeds that section. to make sure it is being supplied power. Since motor is also not working it has to be something they all have in common -POWER!
Sep 06, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
Brush Bar Randomly Stops Turning
There are numerous things that could cause this. It would be best to find a qualified Dyson repair person to determine the cause of your DC28.
Nov 30, 2017 | Dyson DC28 Animal Bagless Upright Vacuum
The beater bar on my Dyson DC14 All Floors Bagles vacuum cleaner doesn't turn. There is no hair or thread caught up in it. All air-flow areas have been checked and there are no blockages that we could...
If it is not on the bare floor setting then you most likely have a belt issue it is not an easy fix I am sorry to say if your mechanically inclined I can tell you how to replace it.
Dec 17, 2009 | Dyson DC14 All floors Bagless Upright...
Brush won't turn.
Hi, W/D here.
You'll need to remove the base plate around the beater bar, and remove any hair that is around the ends of the beater bar. It tends to collect there, along with bits of string, ribbon, and such. When you're removing the hair, be aware of how the beater bar fits in the sockets that hold it in the vacuum frame; you have to replace them in the right way or the beater bar will rub.
Best regards, --W/D--
Aug 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater Bar Quit Working
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
May 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar will not turn
Something probably got caught in the beater bar whilst you were vacuuming, that'll cause it to stop itself so that it doesn't cause any further damage, solution:
- make sure the beater bar is clear of obstructions
- step on the red pedal on the back and recline the handle
- turn the machine on with the red power button
- press the gray button next to the red power button, this is the beater bar's ON/OFF button
- if it still doesn't turn, press and hold the gray button down for 10 seconds
- if after this it still doesn't turn, inspect the beater bar again and make sure there are no obstructions and if there aren't, call the Dyson Helpline, they will set you up with a repair with the closest authorized repair dealer in your area
Apr 24, 2009 | Dyson DC25 All Floors Bagless Upright...
Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
Aug 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC28 Animal Bagless Upright Vacuum Logo
3,879 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
