Question about Endurance Exercise & Fitness
The treadmill keeps shorting out and tripping out everytime i turn it on and now wont turn on at all?
    Problem Solver:
  • 5 Answers
I suspect it is because of the circuit you are using. Please check your treadmill's manual and see how much power it needs. If you dont have the user manual with you, no prob just look at the nameplate on your treadmill. Most treadmills demand a dedicated circuit. Since it is not working at all Please change the circuit. I faced the similar problem few days back.
Posted on Mar 15, 2011
Keeps tripping breaker when put into start mode.
Hi, if you have burnt electrical smell and the breaker keeps tripping you have a short in the motor that's what causes the tripping in the breaker. You will have to get it repaired or claim if it's still under warranty.
Mar 20, 2016 | Bowflex TreadClimber TC5000
My 5.2t Horizon Treadmill turns on, but as soon as I push the start button it blows the fuse to the outlet. I tried re-setting the breaker about 6 times and then I started smelling smoke. I opened the
First of all, never reset a breaker more the once. If it trips twice it's not going to magically, "heal " if you keep resetting it.
Two possibilities. Bad breaker or internal short in the machine.
Replace the breaker with one not tripping and then check out the machine for shorts.
Just switching out parts is a less specific and more costly solution.
Aug 10, 2014 | Horizon Exercise & Fitness
My york treadmill keeps tripping all the electric in my house
1) Unplugged the treadmill, and test if the c. breaker from your house is tripped.
2) If continuos tripped the problem is your HOME, and NOT in the treadmill.
3) Connect the treadmill, if the treadmill NOW tripped the problem is Treadmil.
4) Test the power cord for cross wiring and repair, AVOID any extension cord for feed the treadmillL DO NOT USE.
5) See if the outlet box in your wall is o.k some wires touching between provoking short.
6) open the treadmill, and test the power button for short and replace, see if there are some wires touching the chassis of the treadmill and repair.
see the block diagram and troubleshooitng.
God bless you
Jun 28, 2012 | York Exercise & Fitness
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Apr 30, 2010 | RTO Lifespan Fitness Tr 2000 Hrc Treadmill
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
As soon as i turn the treadmill on it blows a breaker! I just had new brushes put in motor what do u think keeps breaking tripping breaker
Sound like your motor control board has shorted to ground thus blowing the breaker I would have that service company back out ASAP!! to check this unit out.
Feb 08, 2010 | Startrac Fitness Products Star Trac Pro S...
It keeps on tripping the electic
sounds like you have a heating element touching the case or a bare wire in the electrics path shorted to ground and tripping the breaker,re-check all wires and if it has a replaceable cord as in it plugs and unplugs from the unit check this for a short
Feb 06, 2010 | Kitchen Appliances - Others
Exercise & Fitness Logo
725 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
