Question about ASUS P5PE-VM Motherboard
Restart My computer keeps restarting on its own i switched graphic cards and i switched hd's and ram whart else can keep making my computer restart.
  • Anonymous Sep 04, 2008
    my system restart automatically it load untill the "windows loading" again it restart
  • 80 Answers
Try replacing your power supply unit... computer restart is sometimes caused by low voltage output from a faulty power supply.
hope this post helps.
Posted on Aug 01, 2008
My gateway ne522 keeps restarting every time i play a game
From what you describe it sounds like that the computer is overheating when you start a game. Here are some links with pictures to show you how to clean out your computer.
How to Clean the Inside of Computer : Desktop
http://www.instructables.com/id/Cleaning-Your-Laptop-Cooling-System/ : Laptop
Mar 19, 2014 | Gateway Computers & Internet
Why does my computer keep restarting?
It's either running hot, you have a device conflict or a virus.
Try running a virus scan to make sure it's not kicking you off. Check your devices in the device manager to make sure all drivers are loaded.
Remove the power cord, remove the case, take a can of compressed air and blow out the dust from inside the computer, around the vents, around the fans.
If it still runs hot after the above steps, remove the fan that is on top of the CPU and Heat Sink. Clean the dust and apply a fresh coat of Thermal Paste to the CPU and Heat Sink.
Apr 11, 2012 | Computers & Internet
I try to play a game with my graphics card installed but I keep getting a screen full of dots and after a while the computer restarts.What should I do?
Try updating your graphics driver. and lower some of the quality settings in the game so it doesn't push the card as much. If that doesn't help you may need to buy a new graphics card.
Feb 01, 2011 | GeCube ATI RADEON HD 3850, Graphic Card
Monitor shows "no signal" and will not start to windows. I've tried unplugging and replugging it. I've switched dvi and vga cables. The monitor turns on, but keeps on displaying "no signal" and then shuts...
the problum is with the PC, test monitor with a good pc,,
Unplugig all cards and ram chips and re try if it works then puging them back in ..Sounds like the pc has a bad ram chip or card some times they just get bad connection,
Mar 30, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
My monitor screen turned green..
Please check the VGA cable properly its working fine if any brokage then replace with goods one,if still same situation then your display setting has been changed from operating system .go to desktop /right click/properties/setting/advanced/select graphics card/graphics properties/color correction/and select all adnd apply it.
Nov 20, 2009 | ATI RADEON X1650 Graphic Card
Railroad tycoon restarts computer while playing
Hello there,
Usually this happens when the computer is compatible to run the game but not compatible to keep it playing,,, meaning that the computer can execute the game (get it started) but fails to keep it going. The cause of this problem is the graphics adapter so a new graphics card will solve this problem, and remember when buying a graphics card make sure you buy one that is better than the one the game requires.
I hope i solved your problem.
Oct 02, 2009 | Take 2 Interactive Railroad Tycoon 3 for...
Playing cod4, slow jerky poor performance
First of all I hope that you properly uninstalled the graphics drivers and restarted before you installed the graphics drivers for your new card. Old left over drivers can cause a major problem.
Assuming you did it right read below.
What graphics settings do you have it on? And is your firewall set to let it open?
You should also list your processor and the speed and make of your memmory.
I play cod4 on high with an agp .1950 pro @ 1024x768 resolution.
turn off antileasing and aniostropic filtering. Turn all optional settings off but keep textures on medium
No offense but you have the low end version of the hd 2xxx series and can probly only play at medium at best.
You can also go into catylst control panel and make sure the settings are auto balanced.
Jun 01, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
ASUS P5PE-VM Motherboard Logo
434 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
