Question about Honeywell HZ2000C Compact Heater
I have a honeywell HZ-2000C model. The fan works fine but there is no heat generated. I dont know what the problem is.Please help
    Brigadier General:
  • 4,736 Answers
Either the heating element (which is like a toasters) has burned out or the On/Off Heat sensor switch has failed or needs to be reset. Try this to reset the heater. Turn The Master ON/OFF switch to Off. Unplug the heater and wait 10 minutes before plugging it back in. Turn the Master ON/OFF to ON and turn the heater switch to low setting. If the Elements heat up, you've solved the problem. If they don't heat up the heater is toast. The reason I say this, is that they are inexpensive (under $20.00), so it's less of a hassle to just replace it rather than try to repair it. Parts alone would be a bear to find.
Now, if it's still under warranty, then you can either have it repaired or replaced at Honeywells' option. You will need your Proof of Purchase to accomplish this.
Hope this helped in some way, to solve your problem.
Posted on Mar 15, 2011
My honeywell hz 709 heater tipped over slightly and now it will not come on. How do I fix this?
Hello, Usually unplugging the unit and letting tho oil settle for about an hour will reset the unit. Hope this works for you. Please reply and let me know , so if need be I may assist you further. Thank You!
Feb 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Heater will not work
chelk the mains cord,chelk the voltage in the heaters element if no then chelk the heat aduster(thermostate) if current is available on element then your element is burnt replace it.
Jan 08, 2010 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Diagnosing a short cycling honeywell HZ-510 heater
Here is a link to manual and trouble shooting guide. Also service numbers and e-mail contacts. Hope this helps, Thanks and let me know,
Sea Breeze
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hz510.html
Feb 01, 2009 | Honeywell HZ-510MP Ceramic Heater
HZ-725 honeywell cooltouch heater..Lights on but no heat
The screws are "Tamper-Proof Torx" head, it takes a special T15H tool bit to remove the screws. I just disassembled one of these non-working units and the problem with this unit is a open diode on the heater element board. Not sure the purpose of the diode, but no voltage is going through it. I doubt if parts are available as I see no link for parts on the www.kaz.com website. This unit has been quite hot inside as the plastic mounting peg for the heater element board is melted near the diode area.
Dec 24, 2008 | Honeywell (HZ-341BL) Ceramic Heater
Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Jan 02, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell Surround HZ2200 / HZ2204 /
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
SET UP
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Heating)
OPERATING INSTRUCTIONS
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Honeywell HZ2000C Compact Heater Logo
203 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
