Question about KitchenAid KGST307 Gas Kitchen Range
Power won't come on after self cleaning - KitchenAid KGST307 Gas Kitchen Range
  • 3,018 Answers
You might have blown the breaker. Try reseting that. Self cleaning ovens can be hard on ovens in general. You may want to look inside the panel and see if the transformer overheated and is malfunctioning now. Also some wires could have melted in the process. You should have a fuse inside the panel as well. If you have never worked under live voltage I can only recommend you check the breaker in your homes breaker box and have a technician check the rest. Good luck to you.
Posted on Mar 15, 2011
Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Apr 19, 2013 | Electrolux Kitchen Ranges
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
Self cleaning oven won't start
Hi bstetson328 - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self clean option, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Model KESA907P - During self clean, lost power and won't start. Door is locked and totally cooled down. Display is blank w/o power.
I had a similar problem. Got the answer from Macmarkus. Check the HI-Limit Safety Thermostat.
See the thread of our conversations.
Aug 08, 2011 | KitchenAid KESA907P Electric Kitchen Range
Used self-clean mode..oven door wont open..tried fault code still won;t open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | Amana Kitchen Ranges
Can't open door for self clean oven
The door won’t open until oven has cooled as a safety feature. Self clean is high temperatures.
Jan 09, 2018 | Frigidaire GLEFM385D Electric Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
98 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
