Question about Acer AL1912 19" LCD Monitor
I use Acer AL1912 19inch (black) monitor. It is working properly for weeks. but sometime it suddenly go dark during work, although its light remains green. Now the only solution is to unplug its power cable from Monitor and plug after 1 minute to have display again.. I want some repairing solution.
    Scholar:
  • 82 Answers
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Posted on Mar 15, 2011
Acer Aspire 5050 - screen is dark as if contrast not working. It has played up for some weeks, going dark but after 10-15 mins it returns to normal. now it appears permanent. Have adjusted the GAMA and...
put and external monitor and if fail remains then your gpu is damaged, if monitor goes good then your screen is damage or the video cable, so in that case will require a technician to fix it. good luck
Jul 29, 2011 | Acer Aspire 5050-3242 Notebook
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Acer Aspire 3620 Screen
Check Acer's website for a BIOS update. I've seen a LOT of laptop's screen issues been related to the power saving settings in the BIOS. Sometimes screens going black very fast and not working properly can be caused by that.
The Power Inverter could also be the problem which you wouldn't be able to repair yourself. If you purchased it at Best Buy you can take it to them and they could get that fixed for you (at a charge if there is no warranty with that).
Jun 22, 2008 | Acer Aspire 3680 Laptop
Monitor goes Black off and on .....
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1912 19" LCD Monitor Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
