Question about Maytag Microwave Ovens
What is the building code for the distance from the bottom of the microwave to the cooking surface below? I have a Maytag microwave that was manufactured in May 2002 and a Maytag Gemini gas cooking stove.
  • Maytag Master
  • 9,098 Answers
You can check the owner's manual or installation instructions for what the manufacturer stipulates.
If you don't have them, you can download them here.
For building codes, contact your county or city government offices.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
Oct 19, 2017 | GE JVM2070 Microwave Oven
What is the minimum distance from the top of oven to the bottom of microwave
It depends greatly on the ventilation but if you use 20" above the hob, as a good starting point. If you have extractor fans, maybe less. Don't forget the grill gets hot on top of the oven but there should be at least 10" clearence between the grill top and the microwave base, more if it is gas!
Dec 21, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Noise on starting up
If the unit is cooking ok, then it sounds like possibly your cooling fan has the blower wheel rubbing and when the rpm's come up, the blower wheel migrates away from the rubbing surface. It is very common for a blower wheel to loosen up, or a bearing in the bottom end of the blower to fail, causing the sound.
If you dare to venture into the unknown, you can investigate the noise and maybe be able to adjust the attitude of the blower wheel or fan blade, which ever is loose
Post me if I can be of more help.
Thank you,
Dave E. (Illeagle)
Jun 08, 2008 | Maytag MMV5186A Microwave Oven
Whirlpool Microwave excessive grease build up
First you should be sure the ventilation is correct through the oven.
If you don't feel air through the vents when it's running, that needs to be addressed.
Also, it's important to wipe off the interior surfaces whenever moisture seems to be accumulating.
Also, it's recommended to leave the door open a few minutes after cooking to allow it to dry.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 14, 2008 | Microwave Ovens
Above range microwave
According to the installation instructions for this model, the distance from the cooktop surface to the bottom edge of the cabinet (and thus the top of the microwave) must be 30" or more.
Owner's manuals and installation instructions can be downloaded here: http://www.geappliances.com/service_and_support/literature/
Dec 26, 2007 | Hotpoint RVM1635 Microwave Oven
JVM1320WB installation manual
Try this URL:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670536.PDF
Its not exact to this model, but gives enough pointers to assist. Good luck!
Dec 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
148 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
