Question about Scotsman Ice Maker WBin Flake Style water cooled self c
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
  • 3,018 Answers
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Mar 15, 2011
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Sce170a 1b
Top switch is Manual harvest, Middle switch is Purge, Bottom switch is ON/OFF/CLEAN switch. Switch this one to on and it should start the machine.
Dec 08, 2013 | Scotsman Kitchen Appliances - Others
MY SCOTSMAN ICE MACHINE CO33O FREEZING CYCLE IS TOO SHORT AND IS MAKING THIN ICE
There is usually a sensor that the cubes will touch after the cubes thickness builds to a certain point. This sensor should be adjustible.
Dec 04, 2012 | Scotsman C0330SA 1B 300 lb Cube Ice...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
I have a Scotsman AFE400A-1H flaked ice maker, that has started to produce "dirty ice". I have read that the unit has a in-line filter, how do I access the filter, to clean or replace it? ...
Shut it down and have a professional look at it immediately. I do not know of an inline filter and the knocking noise indicates something really bad happening inside of the evaporator / auger housing.
Nov 24, 2010 | Scotsman 22 Wide Ice Maker Bin 242 lbs
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman Ice Maker WBin Flake Style water cooled self c Logo
426 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
john h
John Tripp
John Tripp
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
