Question about Vacuums
Sir can u give me a name which starts with El for instance Eljoy or Elmae...what other baby names possibly starts with El?
Elizabeth or Eliza
Posted on Mar 15, 2011
Hi my name is Sapphire. I have a dyson DC24. The roller bar keeps cutting out, I can't depress the reset button properly and so it won't start up again properly without me trying for ages. The brush bar...
One possibility is a failing reset button, Another option is a bind causing excessive energy to spin it. This will cause the reset button to trip. Check the bearings in the motor and brush roll.
Nov 09, 2014 | Vacuums
The plastic holder for the milk island glass jug is broken. Where can I buy a new on?
Please try to call and contact the company where you bought your unit. They have all the answers for your problem. They have the name of companies and addresses where you can buy the original parts provided you give the unit brand and model name or number.
Jun 12, 2011 | Saeco Vacuums
How to delete or edit phone numbers
Go to Phone book on your phone. It will display the Names List/Phone numbers you have saved.
Click on the number you want to edit/delete. Once the name/number is displayed, click on options and then Edit/Delete the Name/Number.
May 06, 2011 | Vacuums
Could you please tell me, what does DCIM in my sony ipod mean? how can i use that or when do i use that? please
Yes, that is the access to you picture files.
From WIKI:
Design rule for Camera File system (DCF) is a JEITA specification (number CP-3461) which defines a file format and file system for digital cameras, including the directory structure, file naming method, character set, file format, and metadata format. It is currently the de facto industry standard for digital still cameras. The file format of DCF is based on the Exif 2.2 specification.
The latest version of the standard is v 2.3.
The filesystem in a digital camera contains a DCIM (Digital Camera images) directory which contains possibly multiple subdirectories with names such as "123ABCDE", which consist of a unique directory number (in the range 100...999) and five alphanumeric characters, which may be freely chosen and often refer to a camera maker. These directories contain files with names such as "ABCD1234.JPG", which consist of four alphanumeric characters (often "DSC_" or "IMG_"), followed by a number. The file extension is "JPG" for Exif files and "THM" for Exif files that represent thumbnails. Other file formats use different extensions. Multiple files sharing a number (even if the file extension or the four alphanumeric characters are different) are considered related and form a DCF object.
For example, the files on a Nikon D40 are arranged according to the above specification. Thus, a card formatted by the camera will have a partition named "NIKOND40", with a subdirectory named "DCIM". This directory contains a subdirectory named by default "100NCD40", in which images are stored. images are named "DSC_xxxx", where xxxx represents the file's sequential number.
As this is an industry standard, similar directory structures and naming procedures can be found in most digital cameras.
[edit] AccessCamera file systems can usually be accessed by directly mounting them via the USB mass storage device class protocol, which exposes the file layout, whether DCF compliant or otherwise. Alternatively, and independent of DCF, files may be accessed via the Picture Transfer Protocol, which provides an object-oriented view and need not expose the file layout.
The file system layout is often opaque to users, as images are copied onto a computer or printer and the application deals with layout
Apr 11, 2011 | Vacuums
The belt broke. Is is possible to install a new belt and to get replacement part?
Yes you can bye belts from any electrical store and the don't have to be bran names dysons are very easy to replace!!
Jan 17, 2011 | Vacuums
I have no manual
First you want to identify the make of the unit (like Hoover, Eurka, Advance, etc.) After that, you will want to get the Name Plate data. A name plate is simply the a metal stamped, or a Stick on label, with the technical information on the unit Such as Make, Model number, Serial number, Manufactor date, Etc. Name plates are usually very visible, they will be on the Base of the unit [the Canister, for Canister Vacuums, or the Debris collector (bag/bagless) section of the unit, or with some models, The Name Plate will be located on the brush housing,
Nov 30, 2010 | Vacuums
Need vacuum bags and belt for kent model kc-110 c
Call Kent Home Office at 1-800-545-4372. They will give you name of nearest dealer by zip code.
Jan 06, 2009 | Kent Euroclean SelectVac 12HP Bagged...
Brush won't turn
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=751045
Generic problem for all Vacuums
Brush won't turn
Posted by andbecks on Jul 07, 2008
Brush won't turn
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Without knowing the brand name and model #, the reason that your brush is not turning might be you may have a broken belt (always use genuine belts from the brand name manufacturer) and it needs changing, or the bearings in the brushroll are froze up and it would need new bearings or a genuine replacement brushroll. The belt change should be done every 4 to 6 months for the best cleaning, and to store the extra belts in a Ziploc bag in the refrigerator. The next time you request a question, please have a brand name and model # so I can give you more accurate information.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 07, 2008 | Vacuums
Hoover Handle Release Pedal Replacement--How is it possible?
Remove the brush roll, then there 3 screws to remove from the bottom. Then on each side there is a slot, use a flat blade and push on them, then the top rill come loose. That idler arm lock is # 4 in the picture and the knob holds it in place, unless it came off, you don't need to replace it. The handle release #6, there 2 tabs that fit into a holder on each side, stick your screw driver in there and try to twisp and pry it out from the holders, then pop in the new one.
Jul 03, 2008 | Vacuums
The Connector that connects the power head to the hose is worn and does not make good contact. Where can I obtain these two parts.
Please remember to give all the detail you can when posting a question.
Brand name and model numbers are essential minimums among these.
Mar 31, 2008 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
