Question about E-Machines eMachines Desktop PC
I am working on a emachine desktop that had windows xp on it, I am trying to install windows 7 ultimate on it, after formatting the hard drive and setting up a partition, It installs about 81 percent then suddenly the screen goes black and has two white vertical lines on the right hand side of the screen and doesn't do anything after that. I've tried installing it 3 times now and every time it does the same thing. Does anyone have any clue on why it's doing this? the computer was due back to the client a few days ago.. :/
  • tony-t25 Mar 15, 2011
    Does the workstation meet the minimum requirements for Windows 7?
    Scholar:
  • 76 Answers
Http://go.microsoft.com/fwlink/?LinkId=161223
Please check if the Computer supports Windows 7. To check the compatibility of the Computer, please download and Run the Windows 7 Upgrade Advisor. To Download the upgrade advisor, please visit the above link to Download the Windows 7 upgrade advisor. Check if the Device drivers are compatible to Windows 7 if the results are positive then try to perform Clean installation.
Good luck.
Posted on Mar 15, 2011
  • 54 Answers
Your computer -may- be out of date. The visual hardware need to run windows 7 must be up to date, and not made before 2003. Depending on how old your computer is, Windows 7 may or may not run on it. It may also just as well be a problem with your monitor. Is your monitor very old?
How do i format hard drive
It can't format the drive it's using at the time.
If you don't care if it removes everything on the disk, you can boot up from the Windows 7 install disk, and the installer can format your disk.
Sep 12, 2014 | E-Machines eMachines Desktop PC
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
I have my windows xp home premium key but not cd
if you have collected and backed up all the data files on hard drive
then format the drive
contact windows for replacement cd on xp(only way to get it with license key)
re install
then restore files to newly conditioned hard drive
May 28, 2012 | Acer EMACHINE 1GB/160 DESKTOP
Hi, my pc specification is acert650,ddram2(1gb),hdd sata(160gb),cpu3.2ghz.(1) the problem not all win xp pro will get installed.(2) i tried to install win-7 ultimate,but also failed. pls help me . thanks
You need to start with a fresh, fully formatted hard drive (which also checks the physical surface of the drive for errors). Don't choose fast format. Insure that you have enough free space on the partition or hard drive.
Apr 05, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
Dec 14, 2008 | E-Machines T5082 PC Desktop
Change of os
when you go to install xp it will ask you to format the partition anyways so just make sure you're formatting the right partition and you should have no probs. good luck
Jul 31, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
101 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
