FORD MONDEO FITTED WITH SONY CD132 6 CD , INSERT DISC WILL NOT PLAY ,ALL YOU GET IS CHECK CD ,TRYED LOADS OF DIFF CDS
  • 10,594 Answers
Clean its Lens with soft n nice quality cotton swab.
Posted on Aug 01, 2008
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
My sony cd player plays most discs but not all? Why?
I have several CD players and I've found some CDs will just not play on some of them. If you have a changer with 300+ discs they are more likely to be fussy than one loaded in a flat tray.
I'd suggest you try playing the CD in another CD player or your computer, if it won't play in them it is the disk. I had one which would not play in any machine, it was a copy I made on a poor quality closeout of blank CDs at Good Guys when they closed, it turned out the blank CDs were of poor quality.
I hope that might help you.
Apr 21, 2012 | Sony Audio Players & Recorders
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
My ford mondeo 6X CD Sony is playing up all the time with original c.d's Can you help showing change cd check cd then suddenly works Do i need a c.d. cleaner?
The problem maybe that the drive gear that spins the disc is sticky. I had same problem, take cd unti out remove front facia then remove cradle that locks cd into dash. This give access to 4 screws, remove top lid on cd and temp connect facia and cd back in car load cd and watch to see if it spins up if not spin gently with finger. If it plays ok remove and gently oil between black drive disc and motor. Play cd again hopefully this will resolve problem.
Make sure laser is clean of any oil that may have spun off disc.
Best of luck it worked for me.
Apr 20, 2009 | Sony Audio Players & Recorders
My CFD-Z501 won't play a disc. I get the message "no disc"
Try to use CD/DVD clening disk ($6 in Walmart). Or simply use cotton swab (Q-TIP) and 40 % ethyl alcohol (vodka) or 50-70% isopropyl alcohol (NO ACETONE), depending on your budget.
Also check if discs are inserted correctly and not damaged/durty etc. Also check your discs. Some CD-players dont accept burned CDs (copyed). I believe Sony is not the case, just a suggestion.
If cleaning wont help lens might be damaged.
Good Luck
Jan 26, 2009 | Sony CFD-Z501 Boombox
Car stereo
if you have good skill,open it and move the gears with your fingers until the magazine do some movement,maybe it's stuck.do not force anything,look for any disc inserted in play position,that's why the magazine don't come out.
Sep 20, 2007 | Car Audio & Video
CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Sep 16, 2007 | Sony CMT-BX1 Shelf System
Cd Changer will not play CD's
hi does it then say no cds? does it try and load the tray? sounds like it is not reconising that any cds are inserted, could be the laser, faulty or the tray is not reaching the tray in/loaded switch. not worked on many jvc units, so it a bit of guess work regards Mark www.carradiospares.co.uk
Jan 08, 2007 | JVC CH-X470RF 12-Disc CD Changer
361 people viewed this question
 Grubhead
Grubhead
