Question about Dell Computers & Internet
My Dell laptop screen has a white bar that covers 3/4 of my entire screen...i can see a hint of what is behind the white bar, how do i get rid of this bar so I can see the entire screen?
Hi Molly,
This could be a problem with either your drivers, your screen, or your graphics card (or motherboard if it is a cheaper laptop)
To troubleshoot -
If it's a problem with your drivers, firstly restart the laptop and note when the white bar appears. If it appears immediately, then it's not your drivers. If it takes a while to appear (ie, when you're on the windows desktop) then you'll need to update your drivers. Dell support should help you out with this.
If it does appear immediately, then we need to narrow down whether it is your graphics card or your screen. Try plugging it in to an external computer monitor - If the problem is duplicated on the external screen, then it is your graphics card or motherboard. You'll need to replace this. If your computer is under warranty - you should be okay - if it's not, depending on how old the laptop is it's probably a better idea to replace the computer rather than send it off to Dell to be replaced
If it's not duplicated on the external screen, then it may be damage to the laptop screen itself. You'll need to replace the screen. Same conditions as the above paragraph.
Posted on Mar 15, 2011
  • nallen602 Mar 15, 2011
    * if it's not, depending on how old the laptop is it's probably a better idea to replace the computer rather than send it off to Dell to be replaced
    ^ By the above I mean "Buy a new computer". Poor grammar skills strike again!
    Scholar:
  • 82 Answers
Molly, to determine if the problem is with the computer itself or the screen on the laptop, use a VGA connector (if available) to plug the laptop into another computer monitor, if you still see the white bar it's the computer, if not it is the screen, either way you will likely need authorized repairs. I hope this helps.
How to get rid of white vertical line on my laptop
may be an bug in the os or driver or hardware damage check it
Mar 21, 2013 | Dell Computers & Internet
White spots..
Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
take alook there and see if you can tell what to do.
Then I often find that is good to click on START-control panel once there click on display. There you can control your sisplaay and hopefully get rid of the white spots.
all the best
kollagunn
Feb 21, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
WHEN COMPUTER STARTS I GET A BLUE SCREEN AND THEN IT REBOOTS
A very dark blue screen on a laptop that otherwise appears to be "on" is a sign that the backlight on the screen portion of the computer may be burned out. You can test this by shining a flashlight on the screen. If you can see your desktop icons, the backlight is burnt out. Replacing a bad backlight is not a do-it-yourself task unless you are comfortable doing delicate electronic repairs and have the design schematics for your model in hand. Your safest course of action will always be to take the laptop to a professional repair depot. There is one alternative repair option available if you're not comfortable doing surgery and a trip to the repair shop is not in your budget. Replace the entire screen module, case and all.
Doing Surgery Yourself
1.Remove the battery from the laptop. With the laptop model schematics in front of you, use the small Phillips screwdriver to separate the monitor from the laptop base. The schematics will indicate how to uncover the monitor hinges and free the monitor. Handle the screen gently because it will still be tethered to the base by a group of wires.
2.Remove the plastic case covering the "power bar" on the upper part of the laptop keyboard base. Refer to the schematics to find the way to release this cover and lift it off the keyboard. You'll see a group of fine wires leading back to the monitor. Unplug this cable so the monitor is now free from the base.
3.Follow the schematics to remove the casing covering the monitor screen. Be forewarned that the design of a laptop monitor "under the hood" is complex and delicate. Don't force anything. Don't experiment. Take frequent photographs of each successful disassembly stage so you can have some hope of getting it all back together again correctly.
4.Find the slim fluorescent backlight instrument behind the glass layers of the screen. Unplug it from the tiny cable receptacles and remove it. Insert the fresh backlight fixture and reconnect it to the cable plug.
5.Restore the screen assembly and the casing using the schematics and your reference photographs. Plug the screen back into the laptop base at the power bar. Don't reattach the screen hinges to the base until after you have tested it by booting the laptop. If the test is successful, turn the laptop off and connect the screen to the base unit at the hinges.
Alternative Repair
1.Purchase an entire screen-and-case assembly for your laptop make and model. Many intact assemblies are available online for reasonable prices. You will usually pay slightly less for an entire screen-and-case unit than you would for a professional repair on just the backlight alone so this could be an economical alternative for you. You can save even more money by purchasing as "Used but Good" unit, rather than a new unit.
2.Remove your old screen following the previous section's Step 1 through Step 3.
3.Plug the new screen-and-case unit into the laptop base. Follow the schematics and your photographs and thread the monitor wires through the hinge passes. Restore the power bar cover.
4.Test your replacement repair by booting the laptop. If the screen looks normal, shut off the laptop and reattach the new screen to the base at the hinges. Restore the hinge covers.
I hope you find it very helpful. Thanks.
Aug 22, 2011 | Coby NBPC1023XPBLK Netbook PC
White horizontal bar at the bottom of the screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
Apr 10, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
Dell Inspiron D530 - Screen Malfunction - Rainbow colors?
Reseat the display cable (under the keyboard) and while you have the lcd hinge cover off, inspect the cable where is goes thru the hinge assembly for chafing and possible broken wires.
If reseating doesn't help, RUN DIAGS
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=E3FE44D4AAF58D13E0301E0A5517246B&doclang=en#1
If they fail then replacing the LCD display cable and or the LCD would be next.
Dec 09, 2009 | Dell Latitude D530 Notebook
I have a dell inspiron 15 when I turn it on the dell symbol and insprion page comes up then goes to a black screen. When I press F8 I get black screen with white bars at the top and bottom and a white bar...
You are having a display problem with the LCD, so kindly have it checked from dell and get the LCD display replaced from them if your laptop is under warranty
Nov 18, 2009 | Dell Inspiron 8500 Notebook
My compac boots up ok but when im using the pc one of the web pages goes blank(white) and acts as a screen saver. cover the entire screen. covering all icons and margins. just a white screen..even when i...
i have the same problem,also bought new hp for grandson and it to has problem, tried hp help did no good, only cure i found is to hit desk button on keyboard and programs open and on the task bar it will show windows blank page and you can double click and close blank page. hope this helps. robert
Jun 27, 2009 | Compaq Computers & Internet
Black bars
You should right click on your desktop (in the blank space, not on any icon or object) and select the Properties option. This will open your Display properties (but you knew this already). Go to the Settings tab at the end, and see if you can slide the resolution bar to 1280x800. This is the native resolution for your laptop's screen. If you select 800x600, you're widescreen laptop is attempting to display a 4:3 aspect ratio, so it cuts off what it doesn't need. If you select a widescreen resolution, it should automatically adjust so that it takes up the whole screen. If you don't have the option to go any higher than 800x600, you're laptop is missing the correct video drivers and you'll need to reinstall them. You can get the video drivers for your laptop here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
May 13, 2009 | Dell Inspiron B120 Notebook
Enter,Backspace, Space Bar on Dell Latitude not functional
time for new kb same thing happend on one i worked on go on ebay 16 20 bucks easy to replace opo up top cover covering the screen hinges that plastic then under that 3 4 screws hold kb down with ribben cable pop it up out its litt rackets the rippon cable then pull up leave up with new one installed then push down
Jan 26, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
151 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
