Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubuishi DLP Remote Key Sequence
Having the same problem, did you ever find the remote key sequence that corrected your problem? I have the same problem everytime the power goes out...
  • 927 Answers
YES, THANK'S FOR ASKING.
Posted on Aug 07, 2008
No color how to reset to factory settings
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence,,,http://factory-reset.com/wiki/Samsung_Service_Menu
Nov 20, 2013 | Samsung HLN5065W 50" DLP TV
Tip
Procedure to reset Panasonic TVs
If you have replaced the lamp in your Panasonic DLP TV and are having problems such as a message on the screen telling you to reset the lamp timer or the unit not powering up, you probably need to reset the lamp counter. All DLP and LCD TVs which have high intensity lamps generally need to have a lamp timer circuit reset after a lamp change. The manufacturers want to give you a heads up prior to having a catastrophic event such as a lamp exploding which could cause a fire as well as other damage.
Therefore in many cases until you reset the lamp timer the unit will not operate or it will keep reminding you to reset the lamp timer which is very obnoxious. This is not a hard procedure but you will need the original factory remote to accomplish the task. Generally the procedure involves pushing a sequence of buttons.
I recommend placing a piece of masking tape on the rear of the TV with the date the lamp was changed to make it easy to remember when the next lamp change will be necessary. Also you could purchase a lamp now to avoid paying more in the future.
The following procedure should solve your problem:
1. Turn on the television.
2. Press the down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 28, 2010 | Televison & Video
I have no jumper on my samsung dlp to change colors back after changing the color wheel.
hi,,
after the color wheel replacement you need to get the restore sequence procedure using button combination of your remote..
try to to this link www.fixya.com/users/chester_pendilton0
and get any of my services..
thanks
Feb 03, 2012 | Samsung HLP6163W 61" Rear Projection...
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
Sony tv
TURN TV OFF, PRESS 'DISPLAY' ON REMOTE, THEN' VOLUME UP', THEN 'CHANNEL 5', THEN HIT 'POWER BOTTON', ALL IN THAT SEQUENCE, FAIRLY FAST.. THEN JUMP BUTTON( 3) TIMES, THEN CHANNEL 2( 9 )TIMES THAT SHOULD BRING UP LAMP HOURS
Feb 24, 2010 | Sony KDS-60A2000 60" HDTV
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
What is the number for dlp sp46l6hx to open up service menu
the Service Menu on these TVs is accessed by pressing INFO - MENU - MUTE - POWER in quick succession when the TV is in standby. be sure you wright down all numbers before you change anything
thanks
scott
Jul 30, 2008 | Samsung Televison & Video
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Can I tie specific inputs to buttons on the remote, to save having to cycle through multiple inputs
yup you can, but your remote generally need to be able to do what is called a macro. It can be programmed to do several button presses in sequence for you to setup different arrangements for your AV. What model remote control do you have? I can check it out for you. Make and model is good :)
regards
Graeme
Apr 23, 2008 | Televison & Video
Sony rear projection tv kper43m31
All Sony projection TVs have the same remote key sequence to get into the service mode:
display - 5 - volume(+) - power
C-Dog
Feb 09, 2008 | Sony KP-61V90 61" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
