I'm needing the manual for the C17D1329 atomic clok.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Try using the link below. Start your search broad and narrow it down step by step.
http://www.manualsonline.com/
Posted on Mar 15, 2011
How do I re-set my CLOK TCR338 to not read in military time?
heres an answer another question had that might assist u in some way:
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Dec 05, 2014 | Watches
My service light came on, I have 167,000 miles on 2001 Jetta TDI. What service is needed
160.000-engine oil and filtr replace
brake pads and disck heck condycion posible replace
time belt replace
check level oil gearbox
swith off service light:
Switch ignition off
Press and hold buton ( 0.0 ) right said under spido clok
Switch ignition on
Press buton ( hmin) left said under rev-coutner clok engine
The new service interval is displayed
Switch ignition Off
SERVICE LIGHT OFF
finish Good Look
Aug 10, 2011 | 2001 Volkswagen Jetta TDI
Need operating manual for GPX TCR340 clok radio...
Customer helpline: 1-314-621-2881
I have the User's Guide V:1050-0714-09 but cannot make a PDF to upload.
Sep 20, 2010 | GPX TCR340 Clock Radio
Cannot figure out how to set favourite radio stations on my Clok
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
Dec 25, 2008 | Digital Products International Clok Smooth...
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
I can not figure out how to set the times, or the alarm for my new Clok Smooth iPod Docking Clock Radio - TCR368 manual. it did not come with a manual or instructions of any kind.
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Trying to set the timing on this car with a new engine,please help.
timing belt replace v6 engine turn the crankshaft clok wise slowly and make sure that nothing is stoping it for turning, until the key on the mark reach 12 o clok (TDC) the piston no 1 is att the top dead center .if the piston stop before reaching the top dead center ,,,,,one valve or two are open and the cam have to be ajust so dhat valve can close up,,,,,, so after the crank alignement ,the two cam marks at LEFT CAM 2 o clok right cam10 O CLOK ,,,note the belt slack must be on the tensioner side
Aug 03, 2008 | 1990 Lexus ES 250
My digital alarm clock is fast
I'm not on this field of expertise but I could try giving you some tips. These cloks work by dividing the natural oscilations of a quartz cristal in the corresponding way to form "1 second". A quartz cristal like the one in your clock will oscilate at about 14080236 times per second. Your clock uses a specialised chip in order to count these oscilations and know they form "1 second". However, the problem is the following. These clocks doesn't compensate for frequency variation over the mains power line. You should always look firts at it's power ratings and determine if it requires 50Hz or 60Hz. Even if you use an adaptor to raise/lower the tension from 110 to 220 v or viceversa, this woun't correct the problem as the adaptor will leave the frequency unchanged. Unfortunately in order to make the required adjustments you woun't need a resistor or capacitor, but a whole bunch of them in order to make a frequency divider-convertor that's stable enough to give your clock a fixed time reference. One more thing, not all components have exactly the parameters noted on them. There's another thing called Tolerance. A 1Kilo Ohm resistor with 10% tolerance (most comon tolerance) can have any value with +/- 10% of it's noted parameters, and in this example, could have any value between 900 ohm - 1100 ohm. These clocks will need components with a very strict tolerance in order to have an acurate time reference. Note that they aren't atomic clocks, they simply use a larger chip that includes most of the clock, time reference, frequency analyser and divider. An atomic clock doesn't use quartz cristals, instead it relies on the natural oscilations of the very precise Cesium izotope atom. The rest of the atomic clock is made up in a similar way as usual clocks (more fixed and small tolerance of course :) ).
Jun 16, 2007 | Chaney Instrument 66702 Mercury Black...
jasbo
jasbo
