Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Fabric sofner does not work - Equator EZ 3612 CEE Front Load Washer/Dryer
    Genius:
  • 1,075 Answers
The problem is not with the sofner.put a dishwasher [tablet] into your machine and put on hottest wash also put two tablespoons of salt in aswell run machine without load run a secound time as before still at hottest.machine will become ok.Look at it this way clogged arteys in the system same thing.adrian
Posted on Mar 15, 2011
2 Suggested Answers
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
SOFNER WANT LEAVE DESPENSER
Remove the dispenser drawer and soak it in very hot water, the softener get gunked up and won't leave the dispenser.
Mar 10, 2012 | Washing Machines
Making a noise when washing.
in most new models there is a large butterfly knob in the middle of the agitator under the fabric sofner dispensor (take it off) undo the plastic screw take the ag out clean and replace if its an older model it will be a 10mm bolt undo as per plastic screw and replace
Jul 03, 2010 | GE WJSR2080V
Fabric softener doesnot seem to work
Open soap drawer and remove little 'hat' from it's post in the fabric softener compartment. Make sure both are clean and free of softener residue.
Mar 18, 2010 | Washing Machines
Kenmore top loader. agitater won't turn unless you
sounds like the agitator cams are worn out. Pop out the top fabric sofner dome where you would put the downy into. (If your moddel has the green looking snapping ring just below the dome, you would have to snap it upwards and the dome comes off then theres a top cover you jus pop off) . . now you will see the agitator cam. I dont think theres a bolt that holds it down. You have to use a rachet extention that fits into that middle squar shaped hole and unscrew, then take out the agitator cam and replace the 4 little teeth. (make sure you put them in the same way and they slip in there slots ) hopefully this helps...
http://www.partselect.com/KenmoreModels.aspx?ModelNum=11020982992&searchTerm
go to this this link. what you would need is the 3rd picture down. it says "Dog agitator/agitator cams" its the 4 little yellowish looking pieces.
Jul 31, 2009 | Washing Machines
Last 2 loads didn't use fabric sofner
Top load washer? check the agitator. alot of times the softner will gum up the inside of agitator and make dispensing hard
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Softener slot won't drain.
take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite canyon capacity washer
check out the lid switch ... move it up and down slowing and see if you can hear the lid switch clicking.. lid may not be hitting just right or something... should also be under warranty
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
isaac johny
isaac johny
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
