Question about Miele H387B Stainless Steel Oven
The fan in my H387M Miele oven is very noisy sounds like fan is rattling and the oven doesn't get up to temp on display. Replaced cooling fan and problem is still there
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
eagle338
  • 4889 Answers
SOURCE: Jenn Air SVD48600
One of the relay boards is a downdraft relay board....I would be suspecting the main clock assembly as it is the one that shuts down and controls everything. This might also increase the fan speed randomly, turn it on at random temperatures etc., You have to get a new board. You can find it here
http://www.affordableappliance.com
Posted on Feb 27, 2008
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
barkencoa
  • 3463 Answers
SOURCE: NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Thanks.
Posted on Jan 02, 2009
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
Jenn Air SVD48600
Feb 27, 2008 | Ovens
ERROR CODE F6
F6 error code relates to the power board excessive temperature,this points to the cooling fan situated on top of the oven unit being faulty.
You already said it was noisy which is most certainly coo;ing fan.
Hope this helps.
Apr 16, 2010 | AEG CB8920-1-M Electric Single Oven
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Fan noise
It is a cooling fan, and, yes it can be replaced.
Please rate my solution.
Thanks.
Nov 22, 2009 | GE Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Zanuisi top oven making noise
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Miele H387B Stainless Steel Oven Logo
122 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
