Question about Kenmore 63942 Dryer
The other day I was checking to see if my clothes were dry yet, I opened, checked the clothes and then shut the door again. When i went to turn it back on nothing happened
  • 552 Answers
This sounds like you may have a faulty door switch. You read and watch a video that explains how to test this and replace the faulty component at the link below.
Kenmore 63942 Dryer Repair Video Link
http://www.appliancerepairlesson.com/
Posted on Mar 15, 2011
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
My GE dryer shuts down after running for a wile when I open the door to check if the clothes are dry. It seems to start back up after cooling down for about 20 min. Any answers ?
There is an overheat protection thermostat that could be faulty, but it usually indicates that the exhaust tubing is full of lint and there is inadequate airflow. This can be a fire hazard, so you should regularly "Shop Vac" the lint out of the pipe.
Dec 16, 2012 | GE Dryers
DRYER WONT TURN ON. IT WAS RUNNING. TIME WAS UP AND CLOTHES NEEDED MORE DRYING. WENT TO TURN IT BACK ON AND ITWOULD NOT START.
1. Check the circuit breaker for your dryer
2. check to make sure the door switch is operating correctly (this is a safety device that prevents the machine from turning on if the door isn't shut or if the switch is defective.
3. Recheck
May 26, 2010 | Amana DLE330RAW Electric Dryer
Dryer shuts off when I open door ,but timer keeps running
I had this same problem with my Kenmore dryer. If I left it plugged in and door shut it would eventually turn over and start up again. But now my timer is working properly but my dryer won't heat up and dry the clothes. I need help....
Feb 26, 2010 | Kenmore 63942 Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Kenmore 63942 Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
