My washing machine is leaving yellow spots and streaks on all my laundry and the only safe colours to wash are dark colours. Any ideas?
  • 552 Answers
This means only one thing the transmission is bad. You can read several articles and watch a video that explains how to make this repair at the link below.
http://www.appliancerepairlesson.com/
Posted on Mar 15, 2011
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
When I do a wash my dark clothes have white streaks after drying. What do I do?
find the crayon or chalk in the machine. To isolate the issue, line dry some clothes and see if they come out ok.
Jan 07, 2015 | Kenmore 9781 Electric Laundry Center with...
Why do i get white streaks on dark clothes
Well if you use dry detergent than dry using a lighter duty liquid detergent, and be sure to buy the right kind. If your machine is high efficiency the get the h.e. approved detergent.
Apr 20, 2013 | General Electric Washing Machines
Why are there some yellow spots appearing on laundry when it comes out the wash? Thanks
in the washing machine there must be a dust capturer just remove it and clean it maybe there is that yellow thing in it, please rate my answer
Aug 18, 2010 | Miele Washing Machines
Clothing stains
Get a flash light and look very closely at the entire inside of the washer. what you are looking for is a little yellow grease, which is causing this problem. if you find the grease, remove it with a degreaser and you will be fine.
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Calypso grey/dirt streaks
THIS SERVICE POINTER APPLIES TO THE FOLLOWING BRANDS:
LAUNDRY PRODUCTS REFRIGERATION PRODUCTS KITCHEN PRODUCTS
COMMERICAL LAUNDRY
OEM BRANDS
ALL SERVICE POINTERS ONLINE: http://www.servicematters.com/tech_ref/tech_ref_main.htm, SERVICE POINTERS
COMMERCIAL LAUNDRY ONLY: www.whirlpoolcorp.com/cltpsc, TECHNICAL INFORMATION, SERVICE POINTERS
To receive pointers by email or FAX, or to edit or delete a current email or Fax from our distribution, see
http://www.whirlpoolcorp.com/cltpsc/feedback/feedbacksubscribe_all.html, or FAX changes to 269-923-5342.
CALYPSO WASHER
Model: GVW9959K
Serial Code Date: Prior to CP44
GRAY MARKS OR SMUDGES ON CLOTHING
L8178406
October 2003
Gray marks, streaks or smudges on clothing after a wash
cycle.
CONDITION:
CAUSE:
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer.
Jul 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Small dark circles on laundry after washing
if you do cold to warm washs all the time you will get sludge between the drums,try several 95 degree washs with no cloths in it and see how you go .hope this helps.do you use fabric softner.
Mar 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine-dryer AEg
it could be the drum bearings going
Nov 05, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
