Question about Xerox Phaser 8560MFP Laser Printer
I have an 8560 MFP with a 04,024,45 error - Xerox Phaser 8560MFP Laser Printer
  • 2,296 Answers
Power OFF the Printer and Contact Support for Assistance. That's what the support website states. If you run out of warranty Xerox will charge you a call out fee before they even look at the printer.
Posted on Mar 15, 2011
No display
You probably have to replace the display. It is a common problem.
Oct 19, 2014 | Xerox Phaser 8560MFP/SN - 30 PPM...
07 errors are usually a bad Process Drive Motor 005K12670, which is in the front right. Its big bundle of white gears get chewed up, usually due to cracked camshafts 020K14800 or 008K02160.
Afterward, there are important alignments, like latching the printhead in the disengaged position and timing the Process Drive.
Sometimes the screws strip out the chassis, and then you need to repair the mounts using a kit 655N00426.
Good luck.
Whit -- Item, Inc
Dec 30, 2013 | Xerox Phaser 8560MFP/SN - 30 PPM...
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
We have a problem with a Xerox 8560 MFP with this error 37,008.44:34849. We don't known where is the problem. Can you help us ?
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Nov 18, 2010 | Xerox Phaser™ 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... oolivas@gruposion.com.mx cvalabacillascity@hotmail.com
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Trying to remove the printhead for replacement, but the only parts manual I have is for the Phaser 8560 printer, not the 8560 MFP unit. So none of the drawings quite match.
You have to remove the scanner assembly first. Then, to remove the side covers, you have to jab a screwdriver in the right place to release the side cover. It's a bear the first time even with a good drawing.
Jun 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Code 39,003.40:53889
What you can try is shut down the Machine and unplug the powercord and unscrew the cable next to the powercord.
It's from the scanner.
after that reconnect both cable's and turn it back on.
and it should be fixed
Mar 12, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Side cover removal
8650 or 8560?
If its the 8560 you just take the screw out of the back and lift uprards about the middle of the cover. The front cover holds the front together and will pop off.
If you have the MFP version. you will have to take the scanner DADF section off before removing the covers
Jul 30, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
272 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
