Question about Tricity Bendix Washing Machines
Blocked filter light comes on when cycle comes to empty. Filter is clean but pump will not operate.Duomatic 11 years
    President:
  • 1,654 Answers
If the filter is not dirty, then the pump is plugged or has gone bad on this model. You can try using a shop vac and **** the water out of the drain hose to see if anything comes dislogged in the pump or drain hose.
Open up the back of the machine and check the DRAIN PUMP and see if, when you take the hoses off, if there is something inside of it stopping it from spinning or hindering the water flow. If it is clear, check the voltage from the wires to the pump and make sure your getting power to it, if your getting power, also read the voltage and make sure it matches the Placard on the pump. If it is too low, then you probably have a bad switch or computer board. If it OK, and you disconnect the hoses and the pump spins OK, then you probably have a clogged hose.
Posted on Mar 15, 2011
Will run cycle but won't empty
dont know what machine type or model but it sounds like your filter is blocked or your pump clean out the filter first
Sep 26, 2012 | Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Aug 15, 2011 | Frigidaire Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
My machine wont drain or spin. if i maually empty, it will eventually start a wool wash but then says error e20 but filter is clean and no kinks or blockage in drain pipe. should i replace outlet pump?
Do the following.
1. Switch off the machine, unplug or disconnect the mains AC power to the machine and turn off the water supply to the machine.
2. Remove the filter access panel.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 13, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Washing wont empty of water to finnish cycle ive a washer dryer 1100
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
Nov 08, 2009 | Washing Machines
Bosch WFF 2001 has finished a wash cycle but the water will not drain or spin away, cannot open the door. There is no apparent filter trap to empty, help!
Do the following.
  2. Remove the access panel on the lower right front of the machine.
Nov 06, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
