Question about Vacuums
Our dryer has been running longer than normal on cycles. It seems to dry just fine but at times it seems like the timer is not working. The dryer will just keep running for hours. Ideas on what I should do?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Have you checked to see that the knob for the signal to ring is still set to "on"? I know I have accidentally pushed my own off & wondered the same thing as you are.
You may also have an excessive problem somewhere. Check your removable lint filter as it may have too much accumulation on it & is making your dryer run longer.
You should remove it after every few cycles and clean it anyway.
If you use dryer sheets in your dryer, you should also, actually wash that filter to remove any remaining residue from the dryer sheet. You won't see it, but you'll know it's there by running clear water over it, and if it doesn't go thru the screen easily, there's your film.
After taking such good care of your filter & lint traps, check your dryer exhaust, all the way out to the outside of your house. Sometimes a lot of lint gets stuck in there also.. It's important to remove this because any lint that's caught in there could easily start a fire.
If you try all of these things and your dryer is still running too long and your not hearing the signal, I would check to see if the signal is operating first.
Set your dryer to stop in 5 minutes, then watch it. If it keeps running & you don't hear the end of cycle bell, check to see if it's set to "on". If it is set to "on" yet not working, you may have to replace the part or call a service person.....Check to see if your timer is broken or not, too. The wheel could be loose & may only need tightening. Or you may need to call a service person.
This will depend on what part needs replacement, or how handy you are.
I hope this helps.
Posted on Mar 15, 2011
My Shop-Vac 5870400 was working just fine, and then one day while i vac the floor its just stop working, tried to turn on/off a few times, swicth to different outlet. i did even tried to open it, but found...
Same thing just happened to mine. My solution is to get another one but a different brand. I think it should have lasted longer than four years of fairly light usage. From what I read, if it does as we both described, the motor is shot and not worth replacing.
Feb 18, 2011 | Shop Vac 587-04-00 Canister Wet/Dry Vacuum
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
My scooba seems to work fine but no longer makes the beeping noise. Several weeks ago the beep was sounding very strange almost like a battery was dying. Now it's not making any noise at all. Is this the...
Your speaker went out. It could be totally isolated. You're not going to be able to determine what's wrong with your Scooba if something does happen, though, because without those beep codes, there's no way for the robot to communicate with you.
If you're under warranty, call support at 1-877-855-8593 and let them know your speaker went out.
Jun 28, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
SpotBot: Brushed do not rotate
I had the same problem everything worked except the brushes wouldn't move. I took the top off and tested the leads to the motor and it wasn't getting any power. So I took the power board out and traced it to a large ceramic 5 watt 1.5 ohm resistor right in the middle of the board. I got a replacement resistor from a local electronic store and soldered it in. So for less than a dollar its working perfectly again. Also I put some electical tape over the speaker to quiet it down. It seems funny to have a very very loud beep to tell you when a very loud machine is done.
Apr 13, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dyson DC07
This is an incomplete solution. Mine (DC 14 Animal) worked great and then it didn"t and then it did after checking to make sure that all the parts were on securely. I noticed that while the suction sort of seemed normal, it was not strong enough to pick op fine dust from window sills.
The elbow thing near the floor on the right side was not seated properly. I fixed that and it worked great for a while and then lost too much of suction again for no apparent reason. I took a look on the Dyson web sight and they have a trouble shooting guide. The first step is to inspect the main filter and clean it. If I do this again I'll go through the rest of the check process before I clean the filter with cold water as recommended to avoid waiting (12 hours?) for the filter to dry. Mine did not appear dirty and I was unable to rinse out scads of dirt.
I followed the instructions for clearing airways and checking seals... with the canister removed, all suction seems to be fabulous. I'll know in the morning if it really works again after the filter is dry and I can reassemble the thing.
Short version? Try the troubleshooting guide at Dyson.com. I'll try to add to this if it works like new again! All in all, it seems simpler to maintain and trouble shoot that any other vac I have owned.
Good luck,
Tim
Jan 08, 2008 | Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
