Question about Plumbing
Last week my electric power went off for about one hour, in my kitchen I heard water rushing out my drains. when the lights came on I had no water.The well man came and said he had to turn my pressure regulater down five pounds to get my water pump to shut off. Ny pump is running now about every fifthteen minutes and my water pressure is about 1/3 less why? my bladder reads 38lbs
  • 48 Answers
It sounds like the bladder in your pressure tank is water logged. Turn your pump off and open a tap and let the pressure off. Once the water has completely stopped coming out of the tap go to your pressure tank and pump air into it. There should be more water come out of the tap. Continue to pump are in until you reach the pressure recommended for your tank and there is no longer water coming out of the tap. Close the water tap and turn the pump back on and this should fix the problem. If it does not you will probably need a new pressure tank. The bigger the pressure tank you have also will make the pump work less. I prefer a smaller one myself as there is less change in the shower pressure when the pump cycles than with a bigger tank but this is just a matter of prefference. Some people prefer a larger tank as it uses less power by the pump not working as often.
Posted on Mar 15, 2011
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
I have a 93 lincoln towncar with 84k on it. I bought this thing a few months ago from an older gentleman who had not drivin' it in years. I expected alot of problems, but the price was right. So after...
I've never heard of "burping" the coolant system, nor have I ever owned a Lincoln, but based on your description of the problem alone, I would first drain the system, flush it with a good radiator flush (ask the guys at a reputable auto parts store) and refill it - checking all hoses first, of course. While you're at it you might want to check out the water pump and thermostat. The other thing is that the sound you describe as water rush may not be that at all - although i have no suggestions as to what it is. Good luck. . .
JB
Apr 14, 2017 | 1993 Lincoln Town Car
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
I have a GE profile electric oven. My wife is cooking a 15 hr low temp recipe. I just noticed oven off after 12 hours. does it have a safety built in?
Yes. Just think if you rushed to catch your flight for a three week vacation and forgot to turn your oven off before you left? If you check your use and care book, I believe it will tell you how to defeat the 12 hour shut off feature. (also tells how to set or disable the "Sabath" mode, among other settings)
Jan 04, 2009 | Kitchen Ranges
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Plumbing Logo
101 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
