Question about RCA RP5430 Clock Radio
How do you set the alarm and clock? - RCA RP5430 Clock Radio
  • 29 Answers
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Setting Wake Time
This unit allows two wake times to be set.
on the top of the unit to WAKE 1 or
WAKE 2 position.
respective wake time. The time
decrements or increments will follow
by a faster rate when you press and
you are setting the time.
when finished.
http://audiovox2.info/docs/common/RP5430/RP5430_OM.pdf
Posted on Mar 15, 2011
  • 3,018 Answers
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi
https://prezi.com/vgxxmjfbc1ya/sharp-alarm-clock-inustructions/ Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
Nov 05, 2017 | Sharp Audio Players & Recorders
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
Nov 04, 2017 | Audio Players & Recorders
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
Setting the clock?
select the slide on the top to set clock, then use minutes and hour buttons to adjust accordingly, slide to alarm and repeat, press set button if no slide, also, have alarm set to buzzer/radio accordingly, and alarm 1/alarm 2 accordingly if applicable.
Oct 20, 2008 | Audio Players & Recorders
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Sep 06, 2007 | RCA RP5420 Clock Radio
RCA RP5430 Clock Radio Logo
735 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
