Question about JVC AV-32850 TV
Cannot turn off close captioning. our service provided by fios & their box shows the close captioning is off? does tv have its own close captioning and how can you turn it off if you don't have a separate remote for the TV
  • 902 Answers
You can turn it off by accessing the menu button on the tv and cycling thru the options. let me know if that helped.
Posted on Mar 15, 2011
My closed captions all channel is displayed on my vizio tv. I can't get it to go off. I use verizon fios my box doesn't have a menu button on it. Any other suggestions?
Closed captioning is selected during initial set up of your Vizio TV. If you return to that procedure, you can turn off closed captioning.
Dec 07, 2014 | Vizio Televison & Video
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Oct 31, 2013 | Televison & Video
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Philips 50" flat screen - Closed captioning won't turn off
on my magnavox it was the verizon fios remote that enabled it by accident (it is tuned to control the tv) however it was a cc button represented by the * on the remote that i had to select to change the cc. this didn't make it go away so i just pressed buttons i used the "Aspect" button represented by the # it changed the ratio and the message went away. I usually only use the fios remote to turn the tv on and off but this must be some whacky override that comes from the fios remote.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No Closed Caps With HDMI Cable
The information the closed-caption decoder in the TV needs is not provided over the HDMI cable from your converter box. This means the TV's closed-captioning can't be used. But the cable box should provide closed-captioning, so check its setup menus. Contact your cable provider for more information if it's not obvious from the box setup how to turn captions on.
Aug 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
May 07, 2008 | Vizio L32 32 in. LCD HDTV
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Turn off closed caption on input(component) on Sharp Aquos 42"
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Oct 23, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
