Question about HP Pavilion dv6119us Notebook
I have an HP Pavillion laptop (RG279UA) that won't turn on. I tried turning it on with just the power cord and no battery, and I've also tried a different power cord that I know works on another laptop. I have held the power button on for more that 2 minutes each time.
  • 34 Answers
Holding down the power button is not important.
Does the power light flicker at all? If so it just needs a new motherboard.
Try a different power source.
Make sure that the power cords are not kinked and are operational, maybe test it with a multimeter.
Has it turned on before? Recently? Make sure it didn't get left outside
It is probably an issue with the motherboard or the power jack inside the laptop. Try to replace the jack first as it is $15 and motherboards are far more.
Your Friend,
Sleek Mouse
Posted on Mar 15, 2011
  • 902 Answers
Are there any lights on the laptop when its plugged in like the charging light , does the power ***** have a light on it that turns on if neither of those turn on then its hyour power adapter thats it. if they do turn on msg me back
Power black screen failure hp pavillion dv2000
Normally is because the battery is empty or in an error state.
If you plug the power cord and the led still blinking, disconect everything, turn your laptop and search how to take out the battery, wait 1 minute then replug it again and try.
May 25, 2014 | HP Pavilion dv2000t Notebook
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
My Hp 6735s laptop won't turn on, I removed the battery and tried to turn it on using the ac cord only, but still the same problem. I can feel electrical charge on the laptop body. kidher
try to test using voltmeter your power cord charger of laptop maybe loose wiring or damage power supply.if same problem need hp service center that's damage motherboard.
May 23, 2011 | Computers & Internet
Hp pavillion dv9428nr notebook pc wont turn on. it starts to turn on, then turns right off.
i take it it turns off before the bios comes up?
try it with the battery out, maybe it is going off a dead battery, in which case you probably need a new power cord.
otherwise, sounds like a pretty dead laptop, sorry
Oct 07, 2009 | Computers & Internet
HP Pavillion dv2500 laptop won't turn on
Kinda strange. Not turning on indicates a hardware problem, you made software changes. If the software changes caused a problem, it would start, just not boot to windows. I would first tryy to reset the laptop. Unplug it and remove the battery, hold down the power button for 60 seconds, then try again. If still no go, start removing hardware one at a time, hard drive, rem, wireless card, dvd rom. You may have a bad hard drive. Your pc should boot to bios if there is no hard drive installed. If that happens, run a diagnostic on your hard drive from your bios. Let me know if you need anything else.
seth
Jul 29, 2009 | HP Pavilion dv2610us Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion dv6119us Notebook Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
