Question about Cameras
The screen stays black. Yes, I have batteries, I do get instructions and images for video or camera, but I can no longer get a visual of anything the camera is aiming at. It's like there is a lens cap on (even though there is no such lens cap). Camera is only three months old. It worked a week ago. Help. Noreen Natale
  • 34 Answers
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Posted on Mar 15, 2011
My screen is very dim, my pictures turn out clear and light but i cant see anything on the screen, even stored pictures. I have to put my memory card into a different camera or upload my pictures to see...
This problem is only related with back light in lcd screen and has nothing to do with ccd imager chip as explained by previous expert.
LCD screen is not getting enough voltage to lit back light to show its image thus you get darker image.
I suspect back light circuit section at main board got physical damage due to drop of camera. Visual check by qualified camera tech is needed to fix it.
Aug 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Blank screen when taking a picture
Yes it is. Press the DISP button on the back of your camera. This manually turns the screen on and off to save batteries.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Blackness?
Have you tried reading the instructions? How long did you buy it? Try to press the pad or stick like a button inwards. That is how I get the image to go on my digital camera. Did it work?
May 14, 2009 | Canon PowerShot A570 IS Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Image blacked out on LCD and can not see image in view finder
Try connecting it to a computer and then turning on the camera. For some reason that fixed it for mine.
Nov 24, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
66 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
