Question about Whirlpool Refrigerators
Hello. Our whirlpool fridge is too warm now, but no matter how we adjust the temp control from low to high, it still warm like room temperature. It happened suddenly the day before yesterday. Can you tell me how to control the temperature? I saw temperatrue control has "low", "high", and "D001". How can I do to make it cool? Thank you very much. Look forward to your reply.
  • John Tripp
    John Tripp Mar 15, 2011
    That is obviously a problem with the compressor start relay and or start/run capacitor. It could be other things but I need the model number to continue. I will stick with the solution once I have the model number, Thanks, Sea Breeze
  • crazycajun34 Mar 15, 2011
    yes need to know if fans r running and if comp. is running. u could be stuck in defrost.. hope to hear back from u.
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Do rinnai heaters run efficiently if turned up and down often?
Maintaining the lowest acceptable setting and leaving it at that temperature is the most economical way to run the unit. If the space is going to be unoccupied for an extended time (several hours), lower temperatures are okay. This minimizes the need to burst the heat to warm the space quicker. As I understand your unit, it minimizes electrical & gas consumption by basing the need on the temperature difference of actual space temperature and setpoint. The larger the gap, the more power and gas is consumed.
In summary, when the space is occupied, maintain a consistent temperature setting. When the space is unoccupied, maintain a lower setpoint.
Hope this helps. Good Luck. :-)
Feb 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Refrigerator temperature running too high
Oct 03, 2009 | Whirlpool ED2FHEXN Side by Side...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
