Question about Samsung WF337AA Front Load Washer
Ok I get the NF code on my samsung wf337 front-load washer. the water pressure is good the filters are not clogged and the taps are on etc. and this is random I can go a month with no problems and some times its a constant problem. If I bypass the solenoid fill valve (grounding out the coil) just for a second it fills no problem. Is it the control board?
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 380 Answers
SOURCE: We just bought our Samsung WF409. It won't even do
NF is a water supply error. The waters supply valves are malfunction or there is something in the hoses blocking the water. Turn the water off and disconnect them and see if there is anything obstructing the water.
Posted on Dec 18, 2009
  • 159 Answers
SOURCE: Ongoing problem with my Samsung j845. First we got
I am a repairer.this problem is in the electronic PCB.The inlet valve has spiked the PCB.the PCB now is providing constant power to the valve even when not being told to.You have replaced the valve but now runs water as soon as you switch power on at machine.PCB needs to be changed as well.
Posted on May 25, 2010
  • 159 Answers
SOURCE: Samsung washing machine J1045 water over filling
This sounds more like the inlet valve is being supplied with constant power when its not supposed to be.This is normally due to the old valve spikeing the PCB & now you are getting constant power supply to the new valve.I think PCB needs to be changed as well.OE error was an after effect of the machine over filling.
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
Can I get a list of error code and what they mean and how to fix. I keep getting nF as an error. What does this mean?
It means 'not filling'. So either nor or both of your water lines are turned off or just barely open, or the filter screens on your hose washers are clogged. Clean/clear them, or check water flow and you should be good to go.
Mar 10, 2015 | Samsung WF431ABP VRT Steam Front Load...
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
My washer will stop and nf displays and it beeps. what does this mean?
Sorry to read about your problem, I hope this helps you out.
NF means no fill, their is a inbound water issue, water turned off, or clogged hose, etc
remove hoses and check little screens at hose ends..
if thats ok, you may have other issues in the machine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Samsung WF203ANW Front Load Washer
Code nf on display
nf code is no fill ,, washer does not turn on water valves to fill washer with water ,, , chk taps is the water turned on ? check inlet screens on hoses , check wiring connections in harness leading from machine control board to pressure switch,, check water valve ... check inputs and outputs at machine control board ,,
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Nf pops up on the screen & the washer stops
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Samsung WF337AA Front Load Washer Logo
824 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
