Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8500n 70,010.43
I've followed your other 10 posts on the subject but still haven't gotten it to work.
1. Power Cycled 5 or 6 Times
2. I took off all covers and on the left side found the circular spring that held in the 1x1 block. That moved freely.
3. Took the Ink Loader off and obsurved the movement of the print head. It moves to the left (when looking from the front) and then tilts backwards fine. I can see the wiper move up and down, and it's able to shoot out a clean page just fine too, but it still throws up that error
You seem to be the most knowledgable, and I'd really appreciate some pointers!
I couldn't quite see how to get the print head out, but I'm assuming that's the next step. Also on the front side of the print head (towards the drum) there is ink on that, and the wiper doesn't quite seem to touch it - is that normal?
  • tdickson Aug 04, 2008
    Miraculously Got it apart and back together... but that darn error persists!!! Time to call in the experts as I've hit the limit of my skills I think :(
    Thank you very much for your help and hopefully this will help someone else in the same boat!
    President:
  • 2,072 Answers
A little bit of ink in that area can be normal. Although I would clean it out if I were in there.
To remove the print head, you have to remove that block. Then on each side of the print head there is a plastic bracket held in with one screw on each side. They are brass torx screws, they just lift out of the frame on each side of the print head, they are the print head latches.
You mention the head tilts backrward fine, but don't mention it moving forward. Does it get within about 1/4 of an inch of the drum? Is shoul dmove frely forward also. But removing it may be find the problem.
Remove the loose ink.
One other thing to check is the process drive motor. It is mounted on the right side of the machine and has a gear cluster on it. On the clear plastic are timing holes to ling up the gears to the frame. You can just pin them with paper clips. You have to remove the motor to do that correctly, 4 screws and some connectors run across the assembly. Remove it and pin the gears through the holes and when installing make sure the arrow on the frams lines up with the one on the assembly.
Posted on Aug 04, 2008
4 Suggested Answers
  • 57 Answers
SOURCE: xerox phaser 8560 DX error
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Posted on Jan 19, 2011
  • 208 Answers
SOURCE: Xerox Phaser 8500N front control panel LCD died
There is.
Call 1-800-835-6100 and inquire. Don't let them give you a song and dance either.
Posted on Dec 04, 2007
  • 208 Answers
SOURCE: Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Posted on Dec 07, 2007
:I have a Xerox Phaser 8500 with the following error: 13.323.47:31989. Any ideas what this is?
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Jan 09, 2011 | Xerox Phaser 8500N Printer
Error code 02,011.61
The configuration card is for the wrong product.
1. Turn off the printer
2. Verify that the Configuration card is the correct type for the printer
(located at the rear of the printer.)
3. Insert or replace the card
4. Turn on the printer.
5. If the problem persists, replace the main electronics module.
May 28, 2010 | Xerox Phaser 8500N Printer
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8500 does not turn on at all
Most likely the electronics module has gone bad.
Sep 11, 2008 | Xerox Phaser 8500N Printer
Xerox Phaser 8550 DP
This has something to do with the power supply of the machine. Make sure that the machine on a good power source.
Jul 01, 2008 | Xerox Phaser 8500N Printer
Nov 07, 2007 | Xerox Phaser 8500N Printer
Fault 37,008.44:6069
That is a pre heater fault.
Most likley the pre heater needs to be replaced
Aug 29, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
167 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
