Question about Apple Power Mac G4 Desktop
I just install 1.5 GB in my Powermac Quicksilver G4 and now it won't power on. What's wrong?
    Master:
  • 346 Answers
Hello - Sorry you've got the problem.
Let's go over some Powermac RAM rules:
1 - You installed PC133 SDRAM - not PC-100 2 - You installed three 512 Mb sticks and not one 1 Gb and one 512 Mb which won't work or any other combination besides three 512's.
If those are OK you need to:
Remove all the RAM
Install one stick at a time making sure each is firmly seated (you'll hear a small click when it's secure) and power up the machine. after you install each one separately and it boots, then you can install all the RAM knowing the RAM is good. If it doesn't boot with any one stick you've maybe found a bad piece of RAM.
But to be sure (I know it's tedious - but necessary) do the above all over again, but in the next RAM slot - You need to discover if it's the RAM or the Mac.
If the machine still doesn't boot after the testing above (highly unlikely to have three bad pieces of RAM) there probably is another problem besides the RAM. something wrong with the Mac. But most likely you'll be full of RAM and ready to run everything faster and smoother then ever.
Good luck trouble shooting and thanks for using Fix Ya
Mikeywaf
Posted on Mar 15, 2011
  • 3,400 Answers
Make sure access door is closed and latched completely & try pulling power cable for 30 sec then reattach and try restart. If those don't work - contact macsales.com (excellent Apple/Mac folks)
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
I have a powermac G4. When I turn it on it chimes but there is no display and a red light on the motherboard. Checked the power supply - all voltages are good. Bad motherboard or video card?
There is one red LED on the Power Mac G4 QuickSilver logic board. It indicates that there is power to the board and does not imply a fault condition.
Do you hear mechanical activity from the drive? It is possible the machine is running fine except for the display or graphics card. Try another display. If you have another Mac, you can also try starting the machine in target disk mode by holding down the T key at boot (your machine was built in 2001, so it should have this feature) and see if you can access the internal drive from another machine. This should eliminate the motherboard as the culprit.
May 16, 2010 | Apple Power Mac G4 Desktop
Install an Airport card in a G4 Tower
There are six models of Power Mac G4 computers: AGP Graphics, PCI Graphics, Gigabit Ethernet, Digital Audio, QuickSilver, and QuickSilver 2002. You cannot install an AirPort card in the Power Mac G4 (PCI Graphics); the rest accept original version 1 Apple Airport cards. The card is simply inserted through an opening in the PCI card guide and seats itself into a socket on the logic board. Then you attach the loose antenna cable to the hole on the end of the Airport Card. You're done.
Oct 16, 2009 | Apple iMac G4 Desktop
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
The power button is only working periodically
On these PowerMac G4 desktops, the powerbutton works when you press hard and long on it.
If this continue even doing so, I would recommend to take the Mac for repair.
Jun 25, 2009 | Quicksilver Power Mac G4 (Quicksilver)
Mac g4 heatsink
try adding pci slot fans to keep it cool. You can find them on ebay and places newegg.com or any other computer place
Aug 18, 2008 | Quicksilver PowerMac G4 FW800 Heatsink...
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Apple Power Mac G4 Desktop Logo
78 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
