Question about Bionaire BAP1500-U Air Purifier
How do know when it is cleaning air and filter needs changing lost my book. Donot know what to put it on or when to check filter.
Why don't you check it every week or two
Posted on Mar 15, 2011
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Red light on...
the unit probably needs to be reset. cause what's happening is that it's not recognizing that the filters are clean. there should be a tiny pin hole at the top of the unit. when the unit is on you need to put a small needle in there and hold for about 5 seconds and the unit should reset. if that doesn't work please please let me know and i will see what else we can do.
Mar 12, 2009 | Holmes Products HAP725-U Air Purifier
Lost the manual on my Honeywell HFD 110
Found the manual - take my question off this site.
Dec 04, 2008 | Honeywell QuietClean HFD-110 Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Manual for Oure Ion Advanced
the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
Dirty filter
Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
Apr 05, 2007 | Bionaire BAP825-U Air Purifier
Bionaire BAP1500-U Air Purifier Logo
122 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
