Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
How do i set the baud rate to 9600 on the brother mfc-490cw
Noggin
  • 944 Answers
SOURCE: Need User Manual for Brother MFC 9600 All In One
Here's the link; http://www.amazon.com/Brother-MFC9600-Flatbed-Laser-Multifunction/dp/B00004U4A0 Under "product details". Hope this helps :)
Posted on Sep 11, 2007
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
  • 126 Answers
I would advise reinstalling the driver software and let the software re-find the printer again. Should do the trick!
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc490cw_all
Posted on Jul 15, 2009
Craybe
  • 3 Answers
SOURCE: Brother MFC-490CW won't scan
I have had this problem with multiple different Brother products and this has worked for me every time providing your network is up and running.
Reason behind problem: Brother uses a Network Name for the device for access to the printer by the TCP/IP Port, occasionally your dns cache will hold the incorrect IP address for the printer and you need to force the network name to point at the correct IP.
**Note the steps to find your printer IP may change depending on the model of your printer but you can find out where it is in your manual if this doesn't work.
1. On your printer press the menu button. 2. Naviagate to LAN -> TCP/IP -> IP Address 3. When you press ok on IP Address it should show the printers current IP at the top of the page. It will look something like 192.168.0.164 keep a note of this. 4. Back on your computer go to Control Panel 5. Open printers (this may vary slightly by operating system) 6. Find your Brother MFC and right click on it. Then press Properties. 7. Click on the Ports Tab. 8. Select the port that has a tick next to it and press Configure Port... 9. Note down the Port Name: It will be something like BRN_984B5C 10. You can now close all of the printer windows. 11. Open File Explorer 12. Go to C:\Windows\System32\drivers\etc\ 13. There will be a file called hosts (no extention) double click on it and choose Notepad to open the file. 14. At the bottom of this document after all the other text you will need to type in the following (using the information we have found): 192.168.0.164 BRN_984B5C 15. Close and save the file. As you are in Vista you may have some funky UAC windows asking if you are sure you want to save etc. etc. just say yes.
That should do it, your printer will now be able to scan, print & fax from the printer and the printer will be able to find you if you do the same from it's menu.
Hope this helps.
Posted on Oct 29, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
Need the baud rate to be 9600
fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Dec 03, 2008 | Brother IntelliFAX 2800 Laser Fax
Manual
Hi - You can download the manual from the link underlined in blue below:
MFC 9600
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Brother MFC 9600 All-In-One Laser Printer
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
and MFC-7225 only.
Note
14400 bps.
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
MFC 8440D FAX VOIP
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
49 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
