Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp copier sf 7900 paper jammed, trouble code H-4 flashing how to resolve problem
  • Sharp Expert
  • 316 Answers
H4 Heat roller low temperature detection
Posted on Apr 13, 2011
Error code h5-01
That error aprears from having the same paper jam over and over. It is possible that you did not get all of the paper out of the machine. Otherwise most likely you have an issue with a sensor in the paper path you could try blowing all the sensors with canned air. Turn off both power butmtons or use sim 14-1 to clear the trouble and have it try starting up again.
Dec 19, 2013 | Sharp SF 2540 Copier
Sharp sf 7900 copier, after paper jammed and removed the trouble shooting code light H-4 keeps flashing
HELLO
try to remove or unplug the power from the outlet and also same at the back of the printer and wait for 5 minutes and put it back on
just leave comments
thank you
Mar 15, 2011 | Sharp Office Equipment & Supplies
Hello sharp sf-2027 error code F3
This is a paper feed tray problem. Check there is no paper behind the cassette. There may be a tray lift problem and this can be caused by paper being trapped behind it. reset the code once fixed by switching the machine off and on.
Good luck
Oct 10, 2010 | Sharp SF 2020 Copier
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
Error jam code
check for any remaining of torn small pieces of paper===check for no pins or other things inside in paper path=====check for free actuation of paper switches and the lever of the switches in a good condition ------later shut the machine off and then on.
Apr 06, 2009 | Sharp Office Equipment & Supplies
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
