Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water in door side not working - GE (PSS26MSRSS) Side by Side Refrigerator
    Scholar:
  • 89 Answers
This is probably from the frozen water problem on these refrigerators. GE has a problem with the insulation that was used in the doors up to about 2006. Hotpoint has the same problem. I don't know if newer GE-made refrigerators have fixed this, but GE sells a heater to install to keep the pipe from freezing. What has happened is that the water has frozen in the door approximately five inches down the tube. It freezes because the insulation has become compromised (ie, full of moisture) and no longer insulates well enough. People have reported this after a short time of use like 1-5 years. Mine started after about 4 years.
The easiest way to thaw it is to turn the refrigerator off and open the door. Wait a half hour or so and the pipe will thaw out. Another way is to take a hair dryer blower to the pipe - don't let it get too hot so that the pipe melts! This takes just about as long, but the door can remain closed - shorter time if you open the door.
The heater fix from GE just puts off the problem, eventually even the heater won't keep it from freezing. If you are willing to just put off the problem, I suggest taking a piece of fine copper wire about 6 inches long about the diameter of a twist tie (I have used twist ties but the wire is steel and rusts) and insert it into the water tube on the refrigerator after you thaw it out. Leave about 1/4 to 1/2" of wire sticking out so that it picks up heat and delivers it down the wire to the freezing area.
The real repair is to replace the insulation that has gone bad, but that includes taking the door apart or drilling a hole in the door, removing the insulation and stuffing some new insulation in there. I don't recommend this because there is too much chance that you will damage the stuff inside the door. So the other way is to put new insulation on the outside of the inner surface of the door. One person used a flexible Styrofoam sheet (3/8 - 1/2" thick) that was large enough to cover the flat part of the inside of the door. Tape the insulation to door using something like RV roof repair tape (it is white and will adhere mightily to the plastic pieces and the foam and doesn't look half bad). When installing this sheet of material - make certain that the door can close without squashing it. Cut the piece long enough to reach from the area below the ice cube spout to the top of the top shelf.
I have not actually used this insulating method described, but a person on another forum has and it works. The method with the wire works also - I use it on my Hotpoint side-by-side. The other thing to do is raise the temperature in the refrigerator using a lower setting number. I have mine set on 2 rather than 5 that it was set on when I got it. The temperature in the refrigerator should be 35-36 F and the freezer above 0 F. At the 5 setting I had 32 F and -3 F.
Posted on Mar 15, 2011
Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Mar 31, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water no longer dispenses for drinking
Is the water still being supplied to ice maker? Could be 2 things water line froze in door or water valve side supplying the door is out.
Mar 02, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer door lost power, will not dispense ice or water, light does not work Kenmore/10 years old /side by side
Check the door switch.
If the door switch is not working the light will not work and the ice or water will not work.
John
Sep 28, 2009 | Kenmore 57029 Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
