Question about Toshiba Satellite L505-S5966 Notebook
How can i replace my webcam plastic cover on my toshiba satellite L505?
  • 61 Answers
You may need to buy the whole bezel around the LCD, if you have the bezel you jus use a pry tool to open the plastics tabs around the LCD bezel.
Posted on Mar 15, 2011
Toshiba satellite l505 gs6000 amd mobo fried can i replace with the l505 intel board??
if your motherboard is fried and you are running windows it is probably best to find a replacement motherboard of the same make and model so when you go to start it up it should work.
if not you can attempt to have it fit into the laptop but laptop motherboards don't have a standard size so some modifications might need to be made
Jan 06, 2014 | Toshiba Satellite L505D-GS6000,...
Toshiba satellite l505-s6946 not reading disks
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jun 30, 2012 | Toshiba Computers & Internet
Toshiba Satellite L505-LS5014 made a popping noise and then turned off. It had done this 10 minutes before but this time it won't turn on. Any ideas on what's the problem and how to fix it?
The problem may be in the DC jack in the laptop, sometimes solder touch up or DC jack replacement is required. the computer will need to be dismantled down to the motherboard level to address this.
Jun 03, 2012 | Toshiba Computers & Internet
Toshiba l505 s6959 screen flicker
bluestang65c,
An LCD screen cannot produce light by itself.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source. The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's used as lights.
Your Toshiba Satellite L505-S6959 Notebook PC, uses a single CCFL as a Backlight,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~L505-S6959/
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is a little larger than 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Your screen Inverter is going bad.
One example of a screen Inverter for your laptop,
http://nylaptopparts.com/index.php?main_page=product_info&cPath=98_101&products_id=779
The plastic 'frame' in front of your LCD screen, is the LCD Bezel Assembly. (Toshiba)
Behind it, and mounted at the bottom of the LCD Screen Frame, is the screen Inverter.
Pictorial guide in replacing,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L500-L505/remove-lcd-screen-inverter-1.htm
[ Remove ALL power from the laptop. Remove the AC adapter (Charger) and Battery. Follow Anti-Static Precautions ]
This is a link to a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Drop down to the subheading - Satellite A10 (A10 in blue)
Go to the 3rd line in this 'paragraph', (L350D), scroll across, and left-click on L500. (The L505 is part of the L500 series)
Ignore if you are aware of the following;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (L500) it may take up to 30 seconds, before the first page comes up.
(Page 170 in the PDF file header. LCD Bezel Assembly )
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Toshiba Satellite L505-S5988 Notebook
Have a Toshiba Satellite L505. My key was sticking, so I removed it. Under the A key are two smaller plastic pieces. Now I can't figure out how to reattach the key. Thanks!
LOL, it's much easier to just replace the keyboard. You can spend hours trying to get that key back on even if it can be put back on. You might have broken one of the little plastic catches.
May 01, 2012 | Toshiba Computers & Internet
Fn+F8 hot key combination not working on my toshiba satellite L505-es5025
You need to download a launchmanager driver for your machine on the toshiba website.
May 29, 2011 | Toshiba Satellite L505-S5966 Notebook
Toshiba Satellite L505 series laptop would not open windows
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
Feb 19, 2010 | Toshiba Satellite L505-S5966 Notebook
Need users manual
There are 16 different Satellite L505 models. There is a number after L505, like "L505-6826"
Go to this page and at the top of the page is product support. Choose "laptop computer > satellite > then your model number. There is an online manual that you can read from their web site, or download it to your computer. Here's the link (if link is not active, copy and paste into your browsers address bar): http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Hope this helps.
Jul 05, 2009 | Computers & Internet
Toshiba Satellite L505-S5966 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
