Question about Philips Audio Players & Recorders
I have a Philips Cassette Deck a two Head record/player. The capstans are sticking can this be repaired
    Brigadier General:
  • 8,546 Answers
My Retro all in one player ,has a cassette player that plays part of cassette and then cuts off, In other words it doesn't play all of the cassette. Can it be repair ?
this is all i could find out.
The tape could be wound too tightly or the adhesive is sticking to the tape layers. Also, clean the capstan and pinch roller on your deck before playing.also try cleaning the play heads.
or go to this link and see if you can find more info out.
Retro all in one player cassette keeps stopping Google Search
Oct 31, 2017 | The Audio Players & Recorders
I noticed that my az2407 cd cassette player only has one capstan. is that normal?
Most if not all home recorders have only one capstan. Commercial studio recorders have two to maintain tension of the tape on the head of the recorder.
Sep 25, 2014 | Televison & Video
Tascam 238 recording deck will not stop rewinding.
Are you any good at surface mount circuit board repair? It seems that the caps go bad. Check out this: http://www.thegreatbear.net/audio-transfer/8-track-cassette-capstan-motor-tascam-238-syncaset/
Jun 08, 2014 | Tascam 2488 Portastudio Multitrack...
My Teac LP-R500 audio cassette player squeaks when playing. Tapes do not squeak on my other player.
It all depends on where the squeak is coming from. Some very clean rubber parts make kind of a squeak but I don't think that is your problem if you use cartridge cleaning systems. The real answer as a 40 year plus Tape Deck Technician is to get in there and see what is causing the squeak- it may need some oil in reel table, Pinch Roller or even the Capstan Bearing. Manufacturers do not like to put oil into
unit as it makes for no repairs and you will not have to buy a new one.
I worked at Teac but this unit is far after my exit- I still do repairs full time on the product though. I am sure I could resolve it- I am in the Chicago are.
Jan 01, 2013 | Teac R-H500 Dual Cassette Deck
I have a rs-tr 180 that's pulling the tape out of the housing is there a solution?
The tape player recorder that pull the tape out could have the following faults: 1) It has a separate belt from the motor/capstan to the take=up turntable. 2) Capstan roller skew the gap when you bring the mechanism in can be checked and it must be PARALLEL with the surface of each other.3) Faulty cassettes they are binding in their housing due to heat or bad manufacture! Try to rewind and wind your cassette end to end both directions. 4) head alignment not set correctly 5) clutch of take up reel worn or has a bad tension spring. depending how it was made.
Mar 28, 2012 | Technics RS-TR272 Single Cassette Deck
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
I don't know if you can help or not, but i picked up a pioneer stereo/cd/dual cassette player - model xr-p260f at a garage sale. It's really clean and looks like it hasn't had much use. The...
Tape players have several rubber belts in it and if we do not use them frequently belts loosen and become useless and they need to be replaced... . To accomplish this however you need some sort of handy man ability.. Take out the metal cover of the player by removing the screws on the sides .after removing the cover you can access the tape head /transport mechanism. if you look carefully to underneath of tape transport you will see the motor unit which belts will be there...check the belts for the moving mechanism and make sure the belts are not loosen / worn out or broken . You can replace it with a new one that may available in radio Shack stores. Take care..and let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Pioneer Audio Players & Recorders
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
