Question about Chopard Gstaad 32_8128 Wrist Watch
Model number 32/5120 gstaad vintage approx 1987 the stem sometimes comes out! mymemail is martysalins@yahoo.com thank u
    Sergeant:
  • 302 Answers
Take it to Chopard dealer. If that isn't an option take it to a watchmaker that is WOSTEP certified
Posted on Mar 15, 2011
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
I cannot wind the watch, it will not wind up. What is the approx cost to repair.
Just the stem - is about a $40 repair.
If there is clockspring damage - you're looking at $75ish
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Jaeger-lecoultre Reverso Classique 2798120...
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 | Watches
The stem broke off of carrera watch. How much should repair for this problem be?
mcdevito75 here, A new stem and crown Approx. for your Tag Heuer, $125.00 that"s if the stem is broken, if the stem just pulled out it may be able to be saved. Check here at fixya, bottom of page, click on repair service directory the watches.
Jul 03, 2010 | Tag Heuer Automatic Chronograph Series...
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Rado Diastar
your problem is in setting lever,when the setting lever is jumping the stem cannot get back and lock,you better unscrew the complete barrel drum bridge plate take it out ,and the winding pinion is expose,take the winding gear and the setting lever is expose then arrange the alignment,align the winding pinion to the setting lever,alignment is ok.back bridge plate and screw,,make some winding of the crown,let see rachet wheel can turn transmission wheel of complete barrel drum,if can then checked the stem if already lock.,if lock already the job is done,...email if you some question regarding a watch ;lacarontito@yahoo.com
Jun 17, 2008 | Watches
How do i remove crown?
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Chopard Gstaad 32_8128 Wrist Watch Logo
77 people viewed this question
Top Chopard Watches Experts
Jimmy Accardi
Are you a Chopard Watch Expert? Answer questions, earn points and help others
