Question about ASUS P8H67-M PRO/CSM LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Intel Motherboard
My Asus P8H67-M doesnt startup , its led on the MB goes on but thats it, I changed the Cmos battery, put in 1 stick of ram to listen for a beep with speakers in etc.... I have the 24 pin connector and the 8 connected etc... Im using a Sandy Bridge 2600k i7 2x4gigs of Ripsaw ram and a ATI 570 HD Card, along with the standard CD/RW drive and HD The power supply is a Corsiar 850w also btw. I have tried different configurations with the pins etc... 24/18 etc... and no luck. All I get is the green LED on the MB to light up. I checked the power supply and other componets in a diff build on a Asuss Sabertooth x58 with a previous CPU and they all work fine. Any ideas or help maybe a step I missed?
  • 731 Answers
I have had problems like this before have you check the version of the Bios that will run that chip i checked at ASUS and it is 0307 or higher and the newest is 0806. You can read the version on the bios chip or on the box the board came in or if you get it going on the first screen when it starts up.Make sure the Ram is the right clock speed and matched to the board i Have found some power supplies don't work with Asus boards. Also disconnect everything not needed till you find the problem and install one piece at a time and check the bios jumper to make sure it is in the right place.
Drivers and bios update and manual page.
http://support.asus.com/download/download.aspx?SLanguage=en-us&product=1&model=P8H67-M PRO&type=map&f_type=12
Posted on Mar 15, 2011
  • 1 more comment
  • hobbes2k8 Mar 15, 2011
    I dont know what or where the jumper is but I cleard the RTC and no luck still
  • Chris  Ward
    Chris Ward Mar 15, 2011
    Here is a check list from ASUS web Site: try changing CPU if you have one Static from your hands can kill them.and take the board out of the case and try it laying on the pink foam that the board came with some time the board soldier jionts touch the case and the board will sence this and not turn on.
    1 the power LED is on
    1.1 Make sure all cables are connected well
    1.2 Please clear CMOS to have a try(refer to motherboard manual for details)
    1.3 Keep the necessary components ( a CPU, a memory, a graphic card )on board to test
    1.4 If there is still blank screen, please connect the connector of speaker to check if there is any beeps
    1.4.1 If there is no beep, please contact your retailer for a check
    1.4.2 If there is beep, please try to judge from the beep code as the following steps, if the problem still remains after the troubleshooting, please contact your retailer for a check.
    1.4.2.1 Memory issue: Beep (1 long 2 short)
    A Clean the Golden Finger of memory
    B Clean the memory slots
    C Leave only one memory stick to test
    D If convenient, please change different memory to test again
    1.4.2.2 Graphics card issue: Beep (1 long 3 short)
    A. Clean the Golden Finger of graphics card
    B. Clean the graphics card slots
    C. Try to test the onboard graphics card if there is onboard VGA integrated
    D. If convenience, please change different graphic cards to test again
    1.4.2.3 CPU issue: Beep (5 short)
    A. Check whether the CPU is in our CPU support list
    B. Check whether there are any damagers of your CPU or CPU socket.
    C. .Check whether the CPU fan is correctly connected
    D. Check whether the ATX_12V power cable is connected well
    E. If possible try to test with another CPU
    1.5 If the PC could POST after the troubleshooting as the steps 1.3, please plug components back one by one to find out which one may cause this problem
    2 the power LED is off
    2.1 Make sure the power cable which connects to the front panel is well
    2.2 Please swap a power supply for a try if possible.
    2.3 If the problem still remains, please contact your retailer for a check.
  • Mr_Kelp Apr 09, 2011
    My Asus P8H67-M didi not start up either; Now it is fine. It would flash the led power button and the CPU fan would spin a lttle - then nothing. What I did?
    I cleared he CMOS
    Got a 4 pin to 8 pin 12 volt adaptor for the CPU.
    I completely removed the motherboard and notice a metal "spacer pin" was not present next to the CPU (maybe ground to chasis???doubt it); I found it on the back of the mother board I just removed.
    Took out the CPU and re-seated it.
    Moved the RAM to alternate slots
    Re-installed the motherboard
    No more problems.
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
Wont start
If you're not getting a beep code then you can be almost certain the problem does not lie with any of your hardware aside from your CPU.
It is possible your CPU is overheating, in which case you can try to increase the fan speed in the CMOS setup. For further troubleshooting I recommend using isopropyl alcohol to remove the old thermal paste from the heatsink and CPU die, and apply a new, small, pea-sized dab of thermal paste to the CPU die (after which you remount and lock into place the heatsink and CPU fan).
Sometimes these startup problems are very simple, and since you said the fan slows down rather than stopping, it could simply be you have a loose connection somewhere. I'd start with the PSU cables for the motherboard and CPU, and then the fan-monitoring plugs on the motherboard.
Also, it never hurts to load the default CMOS setup, and if you have any expansion cards you'll want to reseat all of them.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Jan 08, 2014 | ASUS Eb1501P-B016E - Eeebox Eb1501P-B016E...
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Dec 22, 2012 | ASUS SiS Chipset CUSI-M Motherboard
Computer powers up but no video even tried with another graphics card
SUGGESTIONS, CHANGE CABLE AND OR DISPLAY. ONLY SUGGESTIONS I HAVE
Feb 26, 2010 | EliteGroup K7VMA Motherboard
L7vmm mb. display went out. Monitor works on
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Apr 17, 2009 | Computers & Internet
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
Mar 19, 2008 | HP Compaq Motherboard
I changed RAM settings in BIOS, now I can't boot - need to clean CMOS
well its quite simple.you have set the wrong latency for rams.
I suggest you put a latency around 3
reset the bios and check the latencyes..you know that you must have all the rams from the computer to the same data..like all the timings or latency.
good luck..
bye bye
Feb 06, 2008 | ASUS P4S533-MX Motherboard
Change RAM
If you put the original RAM back in (both sticks) does the system boot?
Jan 15, 2008 | AOpen XC Cube EA65-II Barebone
Ram issue
you may have to check the speeds of the memory as some boards only take a certain speed after 2GB of ram, forcinh you to use different speed sticks, or look for the cmos clear terminals and clear the cmos settings and restart
Nov 23, 2007 | ASUS P4V8X-X Motherboard
ASUS P8H67-M PRO/CSM LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Intel Motherboard Logo
3,939 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
