Question about Panasonic Technics SL-1200MK2 Turntable
I have a Panasonic SG 106 automatic turntable with radio and tape player combo. When I was moving the moving company shook it up. The belt fell of and the little white thing that the belts goes aroaund broke. Also only one speaker will now work. Can I order the little white think? it looks like a push pin without the pin part. How to fix speakers
mighty thor
  • 51 Answers
SOURCE: Phono chord pins broken off
parties can be rough on audio gear
most turntables I've seen have male rca (phono) plugs on each end, but you have to get to the inside either by taking off the bottom or in some cases the body comes apart in two halves. If you get there and it turns out to be a solder on type (not likely) you can get the tails at radio shack. Most people with any audio equipment at all have an rca stereo pair lying around somewhere.
OR
if you can solder, you can just put new rca ends on the existing cable . Good luck.
at least he didn't break your needle
Posted on Dec 05, 2008
  • 42 Answers
SOURCE: No Amplification
I have answered this.
Posted on Jan 25, 2009
  • 104 Answers
SOURCE: How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Posted on Feb 11, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
  • 133 Answers
SOURCE: Low volume after refitting belt on Technics SL-BS22B turnrable
check also the wire connections on the pickup head, don't forget to check the connections for the same wires inside the turntable, see if you have a bad solder contact to the output terminals, also check the terminals themselves for any dirt/oxydation (i assume they are RCA's, and they DO loose contact if you plug them in and out a lot). Also check RCA's at the amp end.
good luck
3rq8 (Triarcuate)
Posted on Jul 14, 2009
I have got PL117-D Turntable and CT 2OO Tapedeck.Both needs new belt.Where is it possible to get there?Can you help me?Thank you.
Hi u can buy a turntable belt of E/BAY £5.99 recycling-electonics,..,.Radio shack TANDY used to sell an assortment Pack of belts for tape decks etc also u can try (UK Vintage Radio) for the tape deck belts.,..Good luck
Jan 02, 2017 | Audio Players & Recorders
Can not put in a vcr tape
The belt on the loader motor may be slipping or fell off the pulley. There may be something blocking the tape end sensor inside the machine the gears inside may be slipping on their shafts.
Oct 01, 2014 | Sony Rdr-vx535 Dvd Recorder & Vcr Combo...
Fixing Speed on NATIONAL PANASONIC SG-1050A Turntable
If you can there will be either two speed presets under the turntable or on a PC board inside the deck. Or on the motor itself. However this only applies to a belt driven type. A direct drive will have an electronic part fault on it to make it speed up. The electricty supply is nothing to do with the problem.
Feb 20, 2013 | Audio Players & Recorders
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Is it possible to connect my panasonic sg-hm22 to my Denon Reciev
You need an "Audio Output" ie. Tape 2 mon or Rec out (RCA jack) on the Panasonic for it to work. Hope this helps
Jun 22, 2009 | Panasonic Audio Players & Recorders
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
How do I put back the belt that slipped off my turntable?
I had the same problem & came up with this solution. It is very simple.
Take the platter completly off the turntable by pulling on the nipple in the middle of the platter. If you are unsure what the platter is it is the base that the record lies on. It may take a good pull to get the platter off.
Take the belt completly out of the turntable. On the underside of the platter you will see a large circular lip. Wrap the belt around the exterior of the lip. Make sure that the belt is flat & not twisted.
Inside the turntable you will see a large round white gear. On the edge of this gear you will see a semi circle cut out of it with no teeth on it. Align this groove facing front & center of the unit. You can feel it pop into this natural position.
Take the platter & on the underside you will see a small white gear in the center. On the bottom edge of the gear you will see a square notch. This square notch needs to face the front & in center of the unit.
On the inside of the turntable there is a small white wheel on the right side near the record player arm. This is where the belt has to wrap around. This is the motor.
Take the platter & sit it on your lap with the underside facing up. Align the square notch that's on the gear so it is facing 12 o'clock. Pinch the belt at 3 o'clock and pull it a couple inches away from the lip.
Now flip the platter over & be prepared to install it in the unit.
With the belt pinched away from the unit slip the pinched portion over the the small white wheel that is the motor. Put the spindle that is in the center of the platter into the center hole of the turntable. Make sure the belt does not get twisted & that the belt is still on the outside of the lip not getting pinched or hanging off. Remember to keep the square notch that is on the the underside of the platter facing front & center. This step may take a few tries so just be patient.
Now push the center of the platter all the way down as far as it will go.
Turn on the turntable & enjoy your vinyl!
Nov 11, 2007 | Audio Players & Recorders
PANASONIC COMPACT AUDIO SYSTEM MODEL #SG-HM22 help
some models have a hole(s) in the turntable under the mat. You can put your fingers through the holes in the turntable to fix the belt into position. Good Luck.
Oct 28, 2007 | Audio Players & Recorders
Panasonic Technics SL-1200MK2 Turntable Logo
44 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
