Question about Car Audio & Video
Rosen AV7500 Headrest DVD system. Will play DVD, but will not eject DVD. How do I get the DVD out of the unit? I have tried reset button, but it does not resolve the problem.
SOURCE: buttons don't work, wont eject disk
the model you have pictured does not have a dvd,only a monitor
Posted on Aug 21, 2007
SOURCE: rosen a7 dvd player
hi could be a short on the board, need to get it tested.
Posted on Apr 20, 2008
retrohack
  • 27 Answers
SOURCE: Unit Lockup
This fix is for those of you with knowledge of electronic repair......
The problem is a bad electrolytic capacitor on in the power supply board. The cap is a 470uf 16v (number C226 on the power supply board). Replace it with a 470uf with a rating of 25v to 50v and it should restore the power fucntion to normal. I have fixed six units this way so far. Hope this helps you all out!
Retro
Posted on Aug 06, 2008
justuscc
  • 360 Answers
SOURCE: installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Posted on Oct 10, 2008
SOURCE: DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Posted on Jan 07, 2009
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
We have a DVD stuck in the unit and it won't eject or load to play
You need to open player manually and take out your CD. You have mechanism proble and need to check and fix.
Dec 17, 2010 | Rosen A7 Car DVD Player
Dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
Jul 23, 2010 | Rosen CV8081D Portable DVD Player
Rosen entertainment DVD player in a '04 Yukon will not eject
One of the biggest problem facing CD/DVD players are the drive mechanism. When the stay shut or chatter when you try and open them, means the through mechanism that ejects the tray will not push the holding tray open. If you want to open the tray by hand, there is a small hole whereby you can push a pin or paperclip into and push open the tray by hand. That is the only way to open and hand shut the tray into the player and get it operational. Other than that, replace the DVD device...no other choice.
Feb 03, 2018 | Car Audio & Video
System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Nov 03, 2009 | GoVideo DVR4000 DVD Player/VCR
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Buttons don't work, wont eject disk
Jan 08, 2007 | Rosen CV1092 10.4 in. Car Monitor
Car Audio & Video Logo
249 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
