Question about Pioneer VSX-1015 Receiver
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, whenever I switch from per say my Satellite to the Blue Ray I get a clipping noise then the AMP turns off for about a second or two and comes back up, then the volume of the FRONT right channel is way lower than my left, I thought maybe the speaker or the crossover of my right speaker was fried but NO, I swapped my front speakers and still, the sound of the right channel is almost non existent, also while playing any source I notice that there is some very low static noise coming out of my right channel, a noise similar to what old LP vinyl record players used to sound like when dirty. Please help, I hope my AMP is not fried.
4 Suggested Answers
  • 10 Answers
SOURCE: How do I set up a bluray player with my Pioneer
idk
Posted on Apr 06, 2010
michaelhi580
  • 62 Answers
SOURCE: Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Posted on Mar 15, 2011
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Dec 28, 2008 | Pioneer VSX-D411 Receiver
Pioneer vsx d608-no sound
this is an IC failing , it changes the pre amplified audio to the amp.but there is most likely something causing this failure as well ,to much voltage to the chip , it will need testing
Dec 10, 2008 | Pioneer VSX-D608 Receiver
HELP MY VSX 1015TX PIONEER RECEIVER WON'T POWER ON
Try pressing the ENTER + VIDEO2 buttons on the front panel of the unit for 2 seconds. The unit should then come back to life and MCACC should go off.
Sep 10, 2008 | Pioneer VSX-1014 Receiver
Open Questions:
Calibration: low volume, power of all channels is decreased I have the following setup: AV Receiver: Pioneer VSX-1015 Front: 2 x Infinity Alpha 40 Center: 1 x Infinity Alpha Center Surround: 2 x Infinity Alpha 30 Surround back: 2 x Infinity Alpha 20 Subwoofer: 1 x Harman Kardon HKTS200SUB Receiver is new, speakers are used but in good condition, subwoofer is new. ---------- I followed the calibration proces with the microphone. Sound: excelent quality of sound. Never heard anything like this. Good bass, pure and lifelike sounds. Plays loud enough to bother the neighbours. Much bass from the speakers while subwoofer only produces a little bit of ultralow, feelable but not hearable vibrations. ----------- So far so good. Although the sound volume is loud enough for me, it really doesn't reach te output power as pioneer subscribes. In order to play loud I have to turn the volume to almost max. Compared to an old sony receiver (5 x 100 watt rms at 8 ohms 0.07%), the outputted power seems to be much lower. I reach te same (feeling of) power when I turn the pioneer to 80% volume where the old sony reaches that feeling yet at 20% volume. ----------- I noticed that the calibration process decreased the output level of all speakers. With the subwoofer on max (button on the subwoofer itself), I get the following levels: front: -8.0 db / -9.0 db center: -5.5 db surround: -8.5 / -9.0 db surround back: -7.5 db / -7.0 db subwoofer: -10.0 db (MAX decrement!!) All speakers are auto rated as LARGE as they all can deliver good bass. The equaliser has decreased the low frequenties of all speakers and increased the high frequenties. ---------- I tried to manualy increase the output level of the channels. Outputted power increases a lot but doesn't much good for sound quality. I also tried the calibration proces with the sub at half power. Now the sub level is only decreased by 2.5 db and allother speakers are decreased with 2 db less, so a little bit less decrement but stil decreased. ---------- question I have read that increasing the power times 2, puts an extra 3 db to the sound pressure. Watching the heavily decreased db levels on each channel, sounds to me that the receiver works at relatively low power. 7 x 35 watt or whatever... ? Can it be that the subwoofer is too large for this system as it is decremented with the max 10 db? That the system cannot decrease the subwoofer any further so it is going to decrease the speakers? But if that is the case, wouldn't it be more logic that the speakers are incremented and the sub is decremented in level? What about the sound quality? Can it be that the pioneer receiver also measures distortion of the sound? The room where the speakers are in is a small room (20 square meter). Can it be that the receiver decrements all levels in order to reach the highest sound quality? --------- The reason I want to know is because I want to understand the calibration. I am fully satisfied by the sound quality but knowing there might be more in it, is not a good feeling ;-) Thanks a lot!!
Aug 08, 2013 | Pioneer VSX-1015 Receiver
See all Pioneer VSX-1015 Receiver Questions
Pioneer VSX-1015 Receiver Logo
107 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
