My router wont work when it is connected to the modem. the message that on there says limited access
    Problem Solver:
  • 6 Answers
If you already verified that your modem works if computer connected directly to it, try powering down router and modem. Start modem first and wait at least 2 minutes before starting router.
if this doesn't help you will need to verify that your wired connection to router works first before you can attempt to use wireless.
With your computer connected to the router try to open router setup page. Based on router type you should be able to access it from browser using: http://192.168.1.1 or http://192.168.0.1 you will need to login using default admin/admin account or according to router user manual. Configuration page will allow you to verify if you have Internet connection and configure other settings including wireless connection.
Posted on Mar 15, 2011
4 Suggested Answers
SOURCE: My router wont connect to my modem.
unplug the modem then router, each for 15 or more seconds seperately. Do this a few times or until they recognize each other.
Posted on Oct 14, 2009
SOURCE: No connection with access point
if you want for mobile than contact customer service gprs connection and save the connection for the phone Bhoshdina
Posted on Nov 03, 2009
SOURCE: Comcast installed Arris TM602G/CT Modem
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Posted on Oct 09, 2011
Can't access internet or network please help me what action to take.
What is the error message you are getting if any/ on the right hanside bottom of your desktop, in the system tray, what does the network connection say?? Limited or no connectivity?? If its a broadband connection with a router/modem try power cycling.
Turn off the router/modem
turn off the pc/laptop
wait for a minute and then turn on the router/modem
wait for 2 mins and then turn on the pc/laptop and check if its connecting
Please try these steps and then let me know...
Jun 07, 2011 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
Apr 13, 2011 | Computers & Internet
I have set up this device as an AP and connected it to a adsl router, which also has another pc connected to it. I can connect my laptop to the AP and can even access the router, but am unable to browse...
Search in google about how to set up a DHCP server for your router and clone the modem's MAC address, most routers have this option, the thing is some ISPs limit the use of internet to only one machine, by cloning the modem's MAC address in your router you'll make the ISP believe there's only one machine connected to the Internet. By setting up a DHCP server in your router you'll use only one IP to connect all machines using a private network, that should solve your problems. Try both alternatives, and see which one works.
Please check the legal limitations of this procedure for your country or state and have a nice day! ;)
Apr 05, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
Using WRTS4GS2 Cisco Router and could not access the internet. Remobed router and had instant access to the internet.
Contact your ISP. Some ISPs limit the number of computers that can simultaneously connect to your cable-modem. If you change computers, you have to tell your ISP.
Or, power-off your cable-modem, to "reset" it.
Connect the Cisco Router to the cable-modem.
Power-on your cable-modem.
Power-on your router.
Connect your computer to your router, and see if you get Internet access.
Dec 20, 2010 | Computers & Internet
On my windows vista dell laptop it say limited acess to linksys
"Limited access or no connectivity" message comes when there is issue in ip configuration for that enable DHCP in router then set ip get automatic in your windows network adapter's tcp ip property. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then enable DHCP save settings and restart router then go to your windows network adapter tcp ip property then set ip get automatic.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Computers & Internet Logo
David Payne
David Payne
