What is the step by step process in installing a RAM module into an Intel D845GBV motherboard?
    Problem Solver:
  • 23 Answers
1)Shut the computer off and remove the plug in for the Powersupply.
2)Open the case
3)Locate the RAM location. It should be behind the processor and should have a white tab on the end.
4)Depress the white tab on each end which should allow you to remove the RAM. If you are installing make sure they are depressed and push the RAM into place. It should only fit in one direction due to the notches in the RAM itself. After putting them in place push the tabs on the side back up if they have not already latched into place.
5)Then put everything back together and put the case back on.
6)Plug back in and enjoy.
Posted on Mar 15, 2011
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel845 mb 3ghz processor no beep for ram no display motherboard restarting b4 it was giving display ok but when i tried to install antivirus it stuck n when i tried restarting theirs no display n when i...
Just check the motherboard manual because I think you just got problem in hardware compatibility.Remember if your processor and memory are not compatible the first thing that might happen is your process will be damage. But since you it start only when you install antivirus, you have to reformat your disk, to solved the problem.
May 02, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Suitable VGA for my Intel mother board D845GBV
U need to update ur VGA chipset driver as well as ur graphics deriver from http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=889
install & reboot. If still having problem then go to
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=889&OSFullname=OS+Independent&lang=eng&strOSs=38
update ur BIOS version, but note this----BIOS upgradation is very risky task, because during update process power failure will result the abortion of ur motherboard. So do it with experts if u are a rookie.
Feb 21, 2009 | Intel Desktop Board D845GBV Motherboard
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Audio vidoe formatting CD of D845GBV lost
you can get all the drivers you need for the motherboard here:
http://www.intel.com/design/motherbd/bv/bv_drive.htm
kind regards and please don't forget to rate us
Dec 09, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Restarting computer frequently
yeah it is the generic problem of d845gbv, for boot setting change the motherboard battery.
Nov 08, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Intel D845GBV Motherboard Problem
PC1600 runs at 200MHZ and PC2100 runs at 266MHZ..
Since your motherboard only supports a max of 266MHZ, I would recommend that. (not to mention that PC1600 is pretty much obsolete)..
2nd, you motherboard supports a MAX of 2GB Total ram.. So, you could install 1GB + 256MB.. But why not go for 2xGB?
The price for a 1GB stick of PC2100 is around $75-125 CAN. Not soo cheap anymore...
Apr 02, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
